Fitting spacers to front wheels
redpaul
Hi I was recently trying to fit 20mm spacers to my 350z and they went straight on the rear fine but when I was fitting them to the front they wouldnt fit flush because the discs had a stud think with a 10 mm nut to secure the brake disc . Question is do you remove this stud etc . Thanks for any replays
  • 4 weeks later...
What do your front spacers look like Paul? I just bought some eibach ones, rears have their own studs and recessed areas to bolt to hubs, but the fronts are just 20mm plain spacers with about 8 holes all the way round. Would you have to fit extended studs to use these, and are they the standard thing people use on here to space the fronts out or do I need same style as the rear? Hope I've got the right thing as wanted to fit them today 😬
Cheers.
  • 1 month later...
