lukeaJones Posted January 7, 2016 Share Posted January 7, 2016 Has anyone got a guide on removing the front bumper on my 370? Luke Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 7, 2016 Share Posted January 7, 2016 It couldnt be easier dude Pop the air deflector off when you lift the bonnet Remove anything holding it to the undertray and there is 2 bolts under the wheel arch 1 either side Then just pull it away it's that easy Dis connect your battery tho as your airbag sensors are on the back and you don't want those going off Then carefully disconnect all the connections on the back you will lose your washer fluid as well no bigy Good luck Shows you here Doesn't show you everything that's attached on the back though Quote Link to comment Share on other sites More sharing options...
lukeaJones Posted January 7, 2016 Author Share Posted January 7, 2016 Cheers mate í ½í± 1 Quote Link to comment Share on other sites More sharing options...
