turn on issues
Ging4 Ninj4
Ok so I had a issue and code being camshaft sensor bank one, my car would cut out randomly and sometimes would take a few times to turn on. I got a new sensor and fitted and no cutting out anymore but it takes a few cranks to turn on and sometimes won't start first time. Any ideas what this could be???
To start eliminating things: was it a genuine nissan part? was it new? sure you fitted it to the correct bank? sure you fitted it correctly and it's seated properly etc.
For this last point its important as a mm or so out could cause an issue. I think there is a guide on here somewhere ...
I did have the correct part and the correct location. I was told it was a genuine part. The green clip that held it was broke when I went to change it and made it as secure as possible and was very careful as I'm not engine savy lol
The broken clip may be your issue.
Green CPS sensor clips and tails are in stock if required.
