samu23 Posted December 31, 2015 Share Posted December 31, 2015 (edited) Hi All My car has failed its MOT on emissions, reading as follows: Fast Idle Test CO - MAX 0.20% 0.32% FAIL HC - MAX 200ppm 101ppm PASS Lambda - 0.97-1.03 0.99 PASS Second Fast Idle Test CO - MAX 0.20% 0.30% FAIL HC - MAX 200ppm 21ppm PASS Lambda - 0.97-1.03 0.99 PASS Natural Idle Test CO - MAX 0.30% 0.28% PASS The car is an 05 DE zed with 85k miles. I have owned the car for 4 years, and the Cats or sensors in the exhaust have not been changed in this time. The garage were quick to suggest that new cats are required, can anyone shed any light on this? If this is the case I will probably opt for some high flow cats and hope that they will pass. The ECU light is not on and I dont believe there is any fault codes. Any suggestions as to anything else to try other than cats? The car seems to be running well. As a note the car was running on Shell V Power and the car had a good drive immediately before being tested. Cheers, Sam Edited December 31, 2015 by samu23 Quote Link to comment Share on other sites More sharing options...
Ebized Posted December 31, 2015 Share Posted December 31, 2015 Usual trick is to make sure you have given the car a good ragging before dropping the car in for a pre-arranged MOT so that the cats are hot as possible and they are working at peak efficiency. Usually gets over the high readings issue. Quote Link to comment Share on other sites More sharing options...
MIGWEL Posted December 31, 2015 Share Posted December 31, 2015 When i was in the motor trade we sold a bottle of stuff which cleaned out the cats. I think it was called cataclean Quote Link to comment Share on other sites More sharing options...
-G- Posted December 31, 2015 Share Posted December 31, 2015 Going to assume your 05 DE is a UK spec car & not an import? Quote Link to comment Share on other sites More sharing options...
philw99 Posted December 31, 2015 Share Posted December 31, 2015 Dosn't seem that far off to me.. I used to have the same issue on my Audi A3 was really close. bad day and it would fail. So i used to run redex cleaner through the day of the test, passed everytime 1 Quote Link to comment Share on other sites More sharing options...
samu23 Posted December 31, 2015 Author Share Posted December 31, 2015 (edited) First post amended, the reading fo CO has to be 0.2 not 0.3 my error! The garage gave me a bottle of addative to run through the fuel which I did. I've been back for two new readings and they were worse that the first one's above! I will have a look at cataclean. ETA - Yes, UK spec. Thanks, Sam Edited December 31, 2015 by samu23 Quote Link to comment Share on other sites More sharing options...
-G- Posted December 31, 2015 Share Posted December 31, 2015 First post amended, the reading fo CO has to be 0.2 not 0.3 my error! The garage gave me a bottle of addative to run through the fuel which I did. I've been back for two new readings and they were worse that the first one's above! I will have a look at cataclean. ETA - Yes, UK spec. Thanks, Sam Two MOT tester pals say that had hr done a 3rd test it'd have passed - showing a big drop between 1st & 2nd. In their words, find a friendlier MOT place next time because they would have passed it if the 3rd came in. Pouring a full bottle of forte or wurth fuel treatment into tank wouldn't hurt either. 1 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted December 31, 2015 Share Posted December 31, 2015 (edited) redex like this from local halfords...... http://www.amazon.co...QWD239M1PZZ2RZ4 worth a shot david Edited December 31, 2015 by davey_83 1 Quote Link to comment Share on other sites More sharing options...
flyboy Posted January 2, 2016 Share Posted January 2, 2016 Check the exhaust for any leaks however small. If its sucking air it will show as high CO in the lambda up the tail pipe. Quote Link to comment Share on other sites More sharing options...
