Soundwave Posted January 4, 2008 Share Posted January 4, 2008 Howdo peeps, Well after a quick search on here it appears that the Zed takes 6.5" components up front can anyone just confirm that for me??? I'm massivly into my music so the first upgrade when (& if) I get my Zed will be to replace the standard system & seeing as my Leon takes 6.5's up front as well would be nice if I could just swap over the ID Chameleons I currently have in there...because they are great Thanky in advance Neil Quote Link to comment Share on other sites More sharing options...
H5 Posted January 4, 2008 Share Posted January 4, 2008 I think you may well be right, but I'm having 6" components put up front in mine as you get a better range of speakers in that size. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 The factory speakers are 6.5" both front and rear. http://www.350z-tech.com/zwiki/Speakers_%28FAQ%29 Quote Link to comment Share on other sites More sharing options...
Soundwave Posted January 4, 2008 Author Share Posted January 4, 2008 Thanky both Now I seriosuly need to get my finances in order & buy one Oooh quick question as well...whats it like for fitting subs & amps?? I have 2 Genesis Profile amps (P4 & P1) & a Directed Designs 2512 12" sub in a 1.3cu ft enclosure Neil Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 what h/u ? bose ? to fit an amp and sub you need to do a complete install really the bose pushes out peanuts to the sub so any aftermarket sub just want get enough drive Quote Link to comment Share on other sites More sharing options...
Soundwave Posted January 4, 2008 Author Share Posted January 4, 2008 Oooh no sorry It will be run from a Pioneer DEH-p8600MP Head Unit. Neil Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 wierd that, i have (from my last car sitting in the spare room) a pioneer 9600 iirc , a genesis amp and a pair of focal comps and a vibe sub (it sounded ) i know it doesnt look it but there is loads of room to fit audio gear, once the plastics are off behind the seats there is masses of room dynamat xtreme in the boot and wheel arches is a good idea aswell Quote Link to comment Share on other sites More sharing options...
Soundwave Posted January 4, 2008 Author Share Posted January 4, 2008 wierd that, i have (from my last car sitting in the spare room) a pioneer 9600 iirc , a genesis amp and a pair of focal comps and a vibe sub (it sounded ) i know it doesnt look it but there is loads of room to fit audio gear, once the plastics are off behind the seats there is masses of room dynamat xtreme in the boot and wheel arches is a good idea aswell Quality. Should get that gear fitted...although maybe lose the Vibe lol (J/K my mate has a vibe & it does just fine) Reckon lots of Dynamat maybe needed...only real problem I can see is that anybody & their nan will see whats in the boot because of the design...unless I can get one of the Rear Deck Tonneau covers I guess?? Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 i've got a tonneau , that reduces some road noise and gives a bit of privacy into the boot i know the vibe seems chavvy but it worked well the xtreme stuff is expensive but its half the weight for the same sound deadening performance the bose amp is in the boot under the carpet, its easy to do a stealth install on the zed Quote Link to comment Share on other sites More sharing options...
Soundwave Posted January 4, 2008 Author Share Posted January 4, 2008 i've got a tonneau , that reduces some road noise and gives a bit of privacy into the boot i know the vibe seems chavvy but it worked well the xtreme stuff is expensive but its half the weight for the same sound deadening performance the bose amp is in the boot under the carpet, its easy to do a stealth install on the zed Ah so a Tonneau it is then Nah Vibe's are ok if they arent in a Nova/Corsa/Saxo type install Well I've never scrimped on the stereo before so dont intend to now...I'll make sure I pick up some Extreme for it. Oh is the Bose amp a big size?? The footprint for both the Genny Pro's is Pro 4 - (H/W/D) 38 x 217 x 300mm Pro 1 - (H/W/D) 38 x 217 x 300mm So unless I do a full stealth install with a false floor not sure they'll hide under the carpets anyway...not to mention the fact that I'd have to add some extra cooling anyway I guess Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 theres is big space/ glovebox behind the passenger seat, i think both amps would fit in there, maybe throw a fan on the door to keep them happy Quote Link to comment Share on other sites More sharing options...
Soundwave Posted January 4, 2008 Author Share Posted January 4, 2008 theres is big space/ glovebox behind the passenger seat, i think both amps would fit in there, maybe throw a fan on the door to keep them happy Well I'm off to look at 2 Zed's tomorrow so I may have a proper poke around & see whats what space wise & hopefully get a feel for the whole possible ICE install while I'm trying not to spin it into the nearest bush on our crappy roads Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 look behind the seats Quote Link to comment Share on other sites More sharing options...
Soundwave Posted January 4, 2008 Author Share Posted January 4, 2008 look behind the seats Will do. Thanks for all the help & advice so far been great Neil Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 no worries Paul Quote Link to comment Share on other sites More sharing options...
Andy Posted January 4, 2008 Share Posted January 4, 2008 Just be careful with the door speakers as the standard speakers have a pretty small magnet. Anything with a half decent magnet and the window will catch as it reaches its maximum drop. I'll try and get some pics up of my install when I get time to upload them as the boot section is almost finished now!! Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 handy site - http://liljerk.morpheus.net/350Z/ with the front speakers you have 3 choices :- 1, buy some spacers made of mdf (only seen these for sale in the usa - ebay) 2, make your own spacers 3, using the existing speaker spacer which is part of the oem speaker, this does involve destroying the bose speaker (no great loss) another good guide - http://www.350z-tech.com/zwiki/Tutorial ... stallation Quote Link to comment Share on other sites More sharing options...
Soundwave Posted January 4, 2008 Author Share Posted January 4, 2008 handy site - http://liljerk.morpheus.net/350Z/ with the front speakers you have 3 choices :- 1, buy some spacers made of mdf (only seen these for sale in the usa - ebay) 2, make your own spacers 3, using the existing speaker spacer which is part of the oem speaker, this does involve destroying the bose speaker (no great loss) another good guide - http://www.350z-tech.com/zwiki/Tutorial ... stallation Ta for linky's will investigate them later Actually found some spacer rings on UK Ebay for £3.00 http://cgi.ebay.co.uk/MDF-Speaker-Adapt ... dZViewItem I know of a few people who have bought them because it would actually be more expensive to make them yourself lol Neil Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 4, 2008 Share Posted January 4, 2008 handy site - http://liljerk.morpheus.net/350Z/ with the front speakers you have 3 choices :- 1, buy some spacers made of mdf (only seen these for sale in the usa - ebay) 2, make your own spacers 3, using the existing speaker spacer which is part of the oem speaker, this does involve destroying the bose speaker (no great loss) another good guide - http://www.350z-tech.com/zwiki/Tutorial ... stallation Ta for linky's will investigate them later Actually found some spacer rings on UK Ebay for £3.00 http://cgi.ebay.co.uk/MDF-Speaker-Adapt ... dZViewItem I know of a few people who have bought them because it would actually be more expensive to make them yourself lol Neil good find mate , you will need two sets better than messing about order early - Item location: GZ, China Quote Link to comment Share on other sites More sharing options...
H5 Posted January 5, 2008 Share Posted January 5, 2008 Space wise, it depends how far you want to go. There is plenty of space for racking amps behind the seat. There is also the rear speaker 'bar' which also has a couple of cubbies in it. You could remove it, make a replica up using it as a mould, and put whatever you like into it. The cubbies are also big enough to fit 6 disc changers in. Quote Link to comment Share on other sites More sharing options...
