ddcboyle Posted December 29, 2015 Share Posted December 29, 2015 Asked the question on the a5 owners club, they dont seem to like to respond on that forum... Question is, im looking to buy supersprint exhaust for a5, pretty expensive. So i was looking at dpf deletr and the end section, from y-pipe down. So, do i need the centre section or can i use my oem. As in, if it fits... will it make a big difference using oem compared to centre section? Its 400quid for centre bit, and really, if the 2 tail pipes (which will be box free) allow for a good note/power, whats the point in mid sect if only a tiny change? Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 29, 2015 Share Posted December 29, 2015 Need as in fit, or need as in power increase? Ask SS directly for the former, if it's for the latter then I still would. No point in doing things by halves You won't get a decent noise from a diesel though, regardless of exhaust layout. Btw, and I'm sure you know this, but DPF removal is insta-fail on the MOT now. Quote Link to comment Share on other sites More sharing options...
ddcboyle Posted December 29, 2015 Author Share Posted December 29, 2015 Need as in fit, or need as in power increase? Ask SS directly for the former, if it's for the latter then I still would. No point in doing things by halves You won't get a decent noise from a diesel though, regardless of exhaust layout. Btw, and I'm sure you know this, but DPF removal is insta-fail on the MOT now. Thats what i thought about the noise of a diesel, but seen in person. Normally the only noise from a diesel is the engine í ½í¸… Just didnt know if, if it fits over the ypipe, if id lose power/does the y pipe really change the tone much Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 29, 2015 Share Posted December 29, 2015 It's a diesel, it sounds like a tractor. Even the FFRR TDV8 sounds gash, despite it being a V8. I digress though, as I don't know if it's needed to fit either. Give SS a call I reckon, they should be open today. Quote Link to comment Share on other sites More sharing options...
