Easty Posted December 24, 2015 Share Posted December 24, 2015 Anyway the airbag light came on before, iv done a reset (peddle dance) and it's still not working and the light is still on.... Thinking its a sencer has anyone ant ideas or is it a plug in job? Thanks guys Quote Link to comment Share on other sites More sharing options...
ZEUS Posted December 24, 2015 Share Posted December 24, 2015 Have you been messing about with the seats? I use the ignition reset method , works every time. 1 Quote Link to comment Share on other sites More sharing options...
karlh Posted December 24, 2015 Share Posted December 24, 2015 The pedal dance doesn't reset the airbag light; it resets the CEL. Before you reset the light, it might be a good idea to find out why it's flashing in the first place. Quote Link to comment Share on other sites More sharing options...
AMT Posted December 24, 2015 Share Posted December 24, 2015 ...Maybe your airbag has an actual issue? lol Quote Link to comment Share on other sites More sharing options...
Jack wellZ Posted December 24, 2015 Share Posted December 24, 2015 Try pulling the airbag connector underneath the passenger side blowing it a little incase any dust in there (I found it a b**ch to get to) then do the pedal dance. That fixed mine, mine got knocked when a bottle of Coke rolled underneath there Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted December 24, 2015 Share Posted December 24, 2015 (edited) http://m.ebay.co.uk/itm/191716263144?_mwBanner=1 You might need one of these^ I got one last year supplied and fitted for about £100. Edited December 24, 2015 by HEADPHONES Quote Link to comment Share on other sites More sharing options...
TT350 Posted December 24, 2015 Share Posted December 24, 2015 Check there's NOTHING under your seat that shouldn't be there. IE empty cans of Red Bull. Then reset with the ignition technique. 2 Quote Link to comment Share on other sites More sharing options...
Karl92 Posted December 25, 2015 Share Posted December 25, 2015 Mine has started coming up every week or so now its doing my head in, I just use the ignition reset every time Quote Link to comment Share on other sites More sharing options...
Floydbax Posted December 26, 2015 Share Posted December 26, 2015 It's probs the clockspring thingy inside the steering wheel Quote Link to comment Share on other sites More sharing options...
Easty Posted December 26, 2015 Author Share Posted December 26, 2015 Just done the ignition Reset and it seems to of gone, just going to wait and see if it comes back... Thanks guys 1 Quote Link to comment Share on other sites More sharing options...
Chris141084 Posted January 21, 2016 Share Posted January 21, 2016 I had this problem on mine. It turned out to be a bad connection in the plug under the passenger seat for the side airbag. With the ignition off, I simply cut out the plug and reconnected the wires using heat shrink butt connectors. I reset using a computer. Havnt had the problem since :-) Quote Link to comment Share on other sites More sharing options...
LewisL Posted January 25, 2016 Share Posted January 25, 2016 If you need any airbag bits let me know stripping it all out of mine so will all be going on eBay shortly Quote Link to comment Share on other sites More sharing options...
