Oil pressure take off???
nissanman312
Easy job. What input you going to use?
Let me know what you want to do.
No idea mark Ian is doing some work on my car soon so ask him to do this while it's there
I just didn't know where the best place to take the pressure from was and what was needed to do it
I guess he will. I just wanted to learn it Aswell
Not sure if the HR is much different, but the DE should see 14 psi at idle, and 43psi at 2,000 rpm, cold pressure will depend on what the pressure relief valve is set to, I wouldn't expect the HR to be much different, most modern engines run similar oil pressures these days.
Edited by Tricky-Ricky
