ZEUS Posted December 13, 2015 Share Posted December 13, 2015 Ive got a problem with my Mrs Qashqai, clutch pedal started staying down last night and today it's totally gone. I've refilled the reservoir with brake fluid as it was empty and got a bit of a clutch back but then the fluid level dropped to nothing again. I've checked the master cylinder and pipe work and can't find a leak so I'm guessing it's the slave that's buggered? I can't find a leak around the gearbox area though. Any thoughts anyone, am I missing something obvious or do you think it does sound like the slave? It's a 2007 1.6 petrol if that makes a difference. Thanks Chris. Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted December 13, 2015 Share Posted December 13, 2015 If its any help I had a leaking slave cylinder on my old Prelude and you could see the fluid leaked underneath the carpet around the clutch pedal. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 13, 2015 Share Posted December 13, 2015 More than likely the slave, however there should be traces of fluid leak. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted December 13, 2015 Author Share Posted December 13, 2015 More than likely the slave, however there should be traces of fluid leak. That's what's throwing me, the fluids got to be going somewhere. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 13, 2015 Share Posted December 13, 2015 If the CSC has failed then the fluid will eventually leak out from between the engine and gearbox bell housing. I would also check the master cyl. for leaks, however my money is on the CSC. You don't say the year or mileage of your car: So perhaps a warranty claim ? The gearbox has to come out to replace the CSC so worth considering swopping out the clutch and fly when you are in there. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted December 13, 2015 Author Share Posted December 13, 2015 Thanks Alex, Master cylinder looks clean as a whistle and it's a 2007 car with 135,000 miles on it so no warranty. The clutch was done at around 120,000 by previous owner. I was hoping it was the master cylinder because I'd do that myself but I don't fancy scrabbling around under it on my drive to do the CSC. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 13, 2015 Share Posted December 13, 2015 Remember that you can upgrade the CSC which should permanently fix your issues. 1 Quote Link to comment Share on other sites More sharing options...
ZEUS Posted December 14, 2015 Author Share Posted December 14, 2015 All sorted, I took it to the garage today and got it changed so that's me £300 lighter and her Christmas present sorted all in one hit! Thanks for the help Alex 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 14, 2015 Share Posted December 14, 2015 Good to hear that you are sorted Chris. Quote Link to comment Share on other sites More sharing options...
