Engine bay fuse box layout
IDH
Evening all.
After I had checked a fuse for my washer motor in the fuse box behind the battery, my engine light came on.
From previous post of mine on here, from the codes, this is caused by the AF sensors on both banks.
This seems odd, so, going back to my fuse box, after have dropped a spanner under my battery tray, during retreival I find a 15 amp fuse lying there.
So, my suspicion is that I dislodged this which is causing the error.
However, my fuse box layout bears no resemblance to my manual. All the fuses are different amps to what that says.
So, anyone have a photo or can offer any help on the layout and where the AF fuse should be?
I may be clutching at straws but best to check before I take it to the garage.
She is a 2005 GT convertible.
Thanks
Ian
  • 1 month later...
I have a schematic saved somewhere, however this may help in the meantime.
https://www.google.c...KHXOrBAoQsAQIGw
Thanks again Alex. Cant get to the car until the weekend so will take a look then.
Ian
Bit old now, but finally sorted my problem. I had indeed knocked out the fuse for the A/F sensors. Fuse 86!
Cheap fix, phew.
Ian
