djtimo Posted December 8, 2015 Share Posted December 8, 2015 Guys has any one got any tips on improving brake feel of the oem brembo system if I already have 2 piece discs, motul fluid, New pads and brained lines? I'm going to bleed again soon but I have seen brake stiffeners for the brake booster? I'm after more feel and a firmer pedal with more of a defined stop atat the end of pedal travel. Thanks guys. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 8, 2015 Share Posted December 8, 2015 You don't say hot or cold application, however the brake servo stiffener works well, however air in the system or poor choice of pad compound may be your issue. 1 Quote Link to comment Share on other sites More sharing options...
djtimo Posted December 8, 2015 Author Share Posted December 8, 2015 Alex I'm after warm feel. I doubt I have air in the system but I will change fluid and bleed soon again. I'm on a set of brembo pads atm that I swapped in from ds2500. What pad would you recommend? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 8, 2015 Share Posted December 8, 2015 The cheap after market Brembo pad is a budget pad, however it works reasonably well for normal driving. DS2500 would be my obvious choice as an upgrade from OEM for fast road use, however there are plenty others depending on your intended use, You have not stipulated your front and rear set up, although you say 2 piece discs which I assume is fronts. What are you running on the rear ? What brand of 2 piece discs are you running on the front ? Are they fitted correctly ? Quote Link to comment Share on other sites More sharing options...
djtimo Posted December 8, 2015 Author Share Posted December 8, 2015 The cheap after market Brembo pad is a budget pad, however it works reasonably well for normal driving. DS2500 would be my obvious choice as an upgrade from OEM for fast road use, however there are plenty others depending on your intended use, You have not stipulated your front and rear set up, although you say 2 piece discs which I assume is fronts. What are you running on the rear ? What brand of 2 piece discs are you running on the front ? Are they fitted correctly ? Stop tech discs on the front with OEM discs rear. I did have DS2500 but IMHO they felt a little dead when cold? What would you recommend other than those? Do you use a brake booster stiffener?? Quote Link to comment Share on other sites More sharing options...
