HELP!! driving home the eml-slip light or traction control light and abs lights come on
Y23DRH
hopefully some one can help me with my problem with my 2005 vq35de gt roadster 350z
OK couple of weeks ago both my key fobs un-synced them selves now sorted and working again new keys had to be ordered and programed to the car
few days latter the car battery went flat so new battery from Nissan was ordered and fitted thats that problem solved
not sure if the new problem would be anything to do with new battery been fitted but thought i would mention just in case
yesterday whilst driving home the eml-slip light or traction control light and abs lights come on
car wont go over 16mph in any gear and wont rev past 1000rpm in any gear
if i kill the ignition and start the car problem goes away but then quickly comes back about 15 to 20 seconds later
any ideas what could be causing this problem
any help would be very much appreciated
As above ^^
Happened to me once few months back, quick key off and start up again will temporary fix it but luckily mine only happened once and the EML light stayed there. Plugged in an OBD reader and the code pointed it to throttle body sensor. I did the pedal dance to reset my ECU and throttle position. Since then, this never happens again.
I would strongly suggest that you check the fault code first before resetting your ECU.
We found 3 codes
P1274
Are /fuel sensor 1 (bank one) rich condition
P1283
Air fuel sensor 1 (bank 2)
P2138
Wrong acceltor peddle position sensor rationality singnal
I have done the ecu reset and peddle learning and also throttle learning etc
Seems to be working fine now but I would imagine that there is a part that still needs replacing etc
These codes get lots of hits on a google search of the forum, might be worth reading. Paste the below into google search and have a look through.
site:350z-uk.com p1283
site:350z-uk.com p2138
site:350z-uk.com p1274
Good luck
  • 3 months later...
