ianphampton Posted December 7, 2015 Share Posted December 7, 2015 Remember it takes a college degree to fly a plane, but only a high school diploma to fix one; a reassurance to those of us who fly routinely. After every flight, UPS pilots fill out a form, called a 'gripe sheet,' which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way,UPS is the only major airline that has never, ever, had an accident. P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. * P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. * P: Something loose in cockpit. S: Something tightened in cockpit. * P: Dead bugs on windshield. S: Live bugs on back-order. * P: Autopilot in altitude-hold mode produces a 200-feet-per-minute descent. S: Cannot reproduce problem on ground. * P: Evidence of leak on right main landing gear. S: Evidence removed. * P: DME volume unbelievably loud. S: DME volume set to more believable level. * P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. * P: IFF inoperative in OFF mode. S: IFF is always inoperative in OFF mode. * P: Suspected crack in windshield. S: Suspect you're right. * P: Number 3 engine missing. S: Engine found on right wing after brief search. * P: Aircraft handles funny. (I love this one!) S: Aircraft warned to straighten up, fly right and be serious. * P: Target radar hums. S: Reprogrammed target radar with lyrics.. * P: Mouse in cockpit. S: Cat installed. * And the best one for last * P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from the midget. 7 Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted December 7, 2015 Share Posted December 7, 2015 (edited) Seen that before and thanks for a refresh My favourite: something loose in cockpit, something tightened in cockpit Edited December 7, 2015 by Jetpilot Quote Link to comment Share on other sites More sharing options...
Doris Posted December 11, 2015 Share Posted December 11, 2015 ðŸ˜ðŸ˜ðŸ˜ðŸ˜ Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted December 22, 2015 Share Posted December 22, 2015 Just brilliant!!! Quote Link to comment Share on other sites More sharing options...
coldel Posted December 22, 2015 Share Posted December 22, 2015 Number 3 engine missing, engine found on right wing after brief search :lol: Quote Link to comment Share on other sites More sharing options...
ZEUS Posted December 22, 2015 Share Posted December 22, 2015 Brilliant love that, really witty responses. Quote Link to comment Share on other sites More sharing options...
