RDON Posted December 7, 2015 Share Posted December 7, 2015 Hi folks call all wheel experts please! need to check before I buy what would be the correct tyre sizes to buy for the following alloy wheel sizes/offsets so that I don't get traction control problems. 8.5x19 9.5x19 5x114.3 pcd et15 front et20 rear? thanks and KR Rich. Quote Link to comment Share on other sites More sharing options...
Gudzy Posted December 7, 2015 Share Posted December 7, 2015 245/35/19 front and 275/35/19 rear are usually the recommended sizes. 1 Quote Link to comment Share on other sites More sharing options...
BobbyZ Posted December 7, 2015 Share Posted December 7, 2015 I have to say, it seems like there's a huge range of possible tyre sizes for each wheel. Pretty sure I got the above recommendation (amongst others) when I asked for my (hopefully soon to be delivered) 9.5 / 10.5 rims. I know there's a couple of people on here running those rears on 11" rims. Quote Link to comment Share on other sites More sharing options...
RDON Posted December 7, 2015 Author Share Posted December 7, 2015 yeah that's why I wanted advice of the more experienced members. could I go for 40's on each in stead of 35's, does the percentage difference have to be between front and rear wheels OD or from original 18" OD? Quote Link to comment Share on other sites More sharing options...
BobbyZ Posted December 7, 2015 Share Posted December 7, 2015 Too big a difference from OEM rolling radius and your speedo will be off, and too big between front and rear and your TC will throw a wobbler. So ideally, get as close as possible in both measurements. Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted December 8, 2015 Share Posted December 8, 2015 I have run a 275 on a 9.5 and currently 11, 35 is the right profile on both the 245 and 275. Quote Link to comment Share on other sites More sharing options...
RDON Posted December 8, 2015 Author Share Posted December 8, 2015 ok thanks guys very much appreciate your experienced feedback. can I push to ET15 offset on the rear alloys or will it hit the arches with the 19's on? Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted December 8, 2015 Share Posted December 8, 2015 Its 5mm should be fine. Running 11's et 21 with no more than an arch roll. Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted December 8, 2015 Share Posted December 8, 2015 ok thanks guys very much appreciate your experienced feedback. can I push to ET15 offset on the rear alloys or will it hit the arches with the 19's on? All depends on tyre size and what suspension you are on ...... But on a 275 rear with standard suspension you should be fine ..... Just Quote Link to comment Share on other sites More sharing options...
