Toad alarm on a JDM car
88 Zed
I might have - send me a pm and I'll send you what I have.
edit: In fact, I do - found this on another forum a while back. Hope it helps.
1. Remove the transponder from the ignition key ring
2. Disarm the system using an existing transponder tag
3. Switch the ignition on and off twice and then turn the key back on,all within 7 seconds. The LED will flash rapidly to indicate the system is now in programmed mode
4. Pass a new transponder close to the ignition barrel
5. The LED will flash once to indicate that the new transponder tag is in the memory
6. Pass any additional transponder tags close to the ignition barrel
7. For each transponder tag programmed into the system the LED will flash a number of times to indicate how many transponder tags are programmed into the system
8. When you have finished,switch the ignition off and the powerkey will exit the programme mode
9. Each time you programme a new transponder tag into the system it will automatically erase all other transponder tags in the memory, so all the transponder tags required to operate the system must be programmed back in.
Edited by -G-
