stevie_350z Posted January 2, 2008 Share Posted January 2, 2008 Got the old girl out of the garage to find I had a flat at the rear. A quick check all round showed: [mrow][mcol]Stevie's Tyres @ 10am[mcol]Passenger[mcol]Driver [row][mcol]Front[col]22.5[col]29.5 [row][mcol]Back[col]0[col]29.5 I've pumped 'em all back up and will monitor the tyre pressures again tonight. Anyone seen a tyre completely deflate after no use for two weeks - seems pretty unlikely to me. Neighbour just walked passed and said "have you seen those self-tapping screws littered across the car park" I only replaced all four tyres a couple of months ago The tyres are now set to [mrow][mcol]Stevie's Tyres @ 2pm[mcol]Passenger[mcol]Driver [row][mcol]Front[col]35[col]35 [row][mcol]Back[col]35[col]35 Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted January 2, 2008 Share Posted January 2, 2008 can you see anything in the tread steve ? if not check the valve, spit on your finger, smear it across the valve to see if air is leaking Quote Link to comment Share on other sites More sharing options...
H5 Posted January 2, 2008 Share Posted January 2, 2008 Was it only flat at the bottom Stevie? Quote Link to comment Share on other sites More sharing options...
stevie_350z Posted January 2, 2008 Author Share Posted January 2, 2008 Was it only flat at the bottom Stevie? barstard! [mrow][mcol]Stevie's Tyres @ 4pm[mcol]Passenger[mcol]Driver [row][mcol]Front[col]35[col]35 [row][mcol]Back[col]34[col]35 Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted January 2, 2008 Share Posted January 2, 2008 Was it only flat at the bottom Stevie? barstard! [mrow][mcol]Stevie's Tyres @ 4pm[mcol]Passenger[mcol]Driver [row][mcol]Front[col]35[col]35 [row][mcol]Back[col]34[col]35 Looks as if you've got a slow punture bud. Try the valve test that Gixxer suggested and failing that you will need to examine the tread for nails, screws, etc. Quote Link to comment Share on other sites More sharing options...
stevie_350z Posted January 2, 2008 Author Share Posted January 2, 2008 Just been to tescos and back and then did the tyres again - the back one has gone up a bit (warmed tyres, although I was taking it easy?) [mrow][mcol]Stevie's Tyres @ 4pm[mcol]Passenger[mcol]Driver [row][mcol]Front[col]35[col]35 [row][mcol]Back[col]35[col]35 Let's see what tomorrow brings Quote Link to comment Share on other sites More sharing options...
Zummertor Posted January 2, 2008 Share Posted January 2, 2008 Had this on the Audi 2 months ago, found a nail right on edge of sidewall/tread after some hunting around. Only time before that was a much cheaper fix as the valve had failed, a new one for me. May be only answer is to keep it hot Quote Link to comment Share on other sites More sharing options...
MartinGT Posted January 2, 2008 Share Posted January 2, 2008 i'd take the wheel off and give it a good check, i wouldnt fancy a blowout at 70mph due to a nail. Quote Link to comment Share on other sites More sharing options...
