how will wheels with ET 35 offset align with wheel arches
RDON
hi folks. need to pick wheel guru's brains please.. how will 19" 8.5 front and 10 rear with et 35 offset sit/align to the arches on the zed? will spacers still be needed? what is the best ET offset figure on 19" alloys that clear the brembo's with out having to use spacers?
thanks in advance.
I think you will need a lot lower offset to get the wheels fairly flush, I ran 10x19 on my G35 (not sure how similar the arches are, but close I would imagine) they where +22 offset, and in order to get them flush I used a 20mm spacer, so +2 offset, mind you that was pretty close to the arch.
