ioneabee Posted November 25, 2015 Share Posted November 25, 2015 anyone come across this before on locking the car, the drivers window drops half way is this a battery issue or is there a reset process like there is for the 350 Quote Link to comment Share on other sites More sharing options...
Ebized Posted November 25, 2015 Share Posted November 25, 2015 Search is your friend Quote Link to comment Share on other sites More sharing options...
Ebized Posted November 25, 2015 Share Posted November 25, 2015 To do the window reset, start the car, push the window open button until the window opens fully and keep holding it down for 5 seconds. Then pull it up to fully close the window, again holding it up for 5 seconds once closed. Or try this ADDITIONAL SERVICE WHEN REMOVING BATTERY NEGATIVE TERMINAL : Special Repair Requirement INFOID:0000000004460995 INITIALIZATION PROCEDURE 1. Disconnect battery negative terminal or power window switch connector. Reconnect it after a minute or more. 2. Door switch is OFF (close). 3. Turn ignition switch ON. 4. Operate power window switch to fully open the window. (This operation is unnecessary if the window is already fully open.) 5. Continue pulling the power window switch AUTO-UP. Even after glass stops at the fully closed position, keep pulling the switch for 3 seconds or more. 6. Initializing procedure is completed. There you go. Quote Link to comment Share on other sites More sharing options...
ioneabee Posted November 25, 2015 Author Share Posted November 25, 2015 On 25/11/2015 at 14:31, Ebized said: Search is your friend yea window reset FTW I wonder what caused that then Quote Link to comment Share on other sites More sharing options...
Richf Posted November 25, 2015 Share Posted November 25, 2015 A disruption in the power supply to the door usually causes it , blown a fuse or had the door card off ? Quote Link to comment Share on other sites More sharing options...
ioneabee Posted November 25, 2015 Author Share Posted November 25, 2015 nope - neither (that i've spotted) Quote Link to comment Share on other sites More sharing options...
