tojodog Posted November 15, 2015 Share Posted November 15, 2015 my airbag warning light as started continuously flashing any info cheers Quote Link to comment Share on other sites More sharing options...
Gudzy Posted November 15, 2015 Share Posted November 15, 2015 http://www.350z-uk.com/topic/3047-guide-resetting-airbag-warning-light/ I'd suggest you check nothing is loose under your seats and disconnect and then reconnect the electrical connectors under the seats and then follow the reset procedure I've linked to as those are the usual culprits. Quote Link to comment Share on other sites More sharing options...
tojodog Posted November 15, 2015 Author Share Posted November 15, 2015 sorted top man gudsy cheers for that your a star Quote Link to comment Share on other sites More sharing options...
DarmoZ Posted December 10, 2015 Share Posted December 10, 2015 When i had my new sound system installed, i would notice the airbag warning light would come on and stay on if i put my volume really high, maybe the bass from the door speakers was causing this i dont know. After a couple resets using the key method (on youtube) the airbag light hasnt returned since, even if i crank up the volume. Quote Link to comment Share on other sites More sharing options...
