Kraziekatz1 Posted November 11, 2015 Share Posted November 11, 2015 Hey guys, my battery is on its last legs & I've just bought a replacement. Left work early so I could switch them over and I can't work out how to get the battery out without, what seems, removing half the car. I'm trying to do it in the dark with a torch, but the bulk of the battery seems to be tucked away under the engine cover. If I undo the long bolt/battery support, how do I slide it out? It doesn't look like it will fit through the gap! Quote Link to comment Share on other sites More sharing options...
Humpy Posted November 11, 2015 Share Posted November 11, 2015 Mine was a tight squeeze to get out and to get back in. Maybe try in the light if possible just to make it easier. Quote Link to comment Share on other sites More sharing options...
Shenley Posted November 11, 2015 Share Posted November 11, 2015 You have to remove the battery cover surround. Just a few clips. Then make sure the fuse box is out of the way and it just comes out at an angle. The rear bolt/screw/fastener is on a short hook and doesn't go to the bottom tray. Best done in daylight. Quote Link to comment Share on other sites More sharing options...
HaydnH Posted November 11, 2015 Share Posted November 11, 2015 You have to remove the battery cover surround. Just a few clips. 4 clips if I remember right, they're the weird pull the middle pin half way out and then pull the whole lot type clips - if you pull the middle pin fully out the outer part of the clip won't come out of the hole. Quote Link to comment Share on other sites More sharing options...
JetSet Posted November 11, 2015 Share Posted November 11, 2015 Best done in daylight. Yeah, changed mine twice, you definitely need good lighting. Pete Quote Link to comment Share on other sites More sharing options...
Kraziekatz1 Posted November 11, 2015 Author Share Posted November 11, 2015 Brilliant, thanks guys. I saw the clips and did wonder if I had to take it all out. Much appreciated Quote Link to comment Share on other sites More sharing options...
veilside z Posted November 12, 2015 Share Posted November 12, 2015 Are you all sorted now buddy? Quote Link to comment Share on other sites More sharing options...
Kraziekatz1 Posted November 12, 2015 Author Share Posted November 12, 2015 No, it was too dark last night. Thought Hubby might offer to help (hold the torch at least).....but no Didn't have time this morning.....might try and get out of work early Friday or else I'll do it at the weekend. From the photo above, I think I should be ok though thanks ........the skin's just grown back over my knuckles from replacing the battery & headlights in the Scooby lol Quote Link to comment Share on other sites More sharing options...
Kraziekatz1 Posted November 14, 2015 Author Share Posted November 14, 2015 Job done. Glad I waited to do it daylight! Thanks for the help guys, much appreciated Quote Link to comment Share on other sites More sharing options...
