Changing plenum chamber - anything to look for?
H5
Thanks for that bud, some useful stuff in there. :thumbs:
Since it is going on soon, I may as well tell.....!
I am actually swapping it out for a polished version of the same. The only other one I'd go for is the Cosworth, but from the looks of it, there is a gasket between the upper and lower plenum - is this cork? Metal? Something else? Also wondered about torque settings for doing it back up?
In a nutshell, am I ok pulling the usual socket set and wrench out, and doing this myself? I'm not a complete novice, but have no back up if I mess something up! :blush:
metal gasket between plenum, I seem to remember when I swopped mine (long time ago now :blush: ) :thumbs: just get good quality allen key's to undo the bolts as they can strip out the centres easily.. I used a torque wrench to retighten as it easy to overtighten the 6mm bolts and strip the threads :) and dont drop anything down the inlet :lol:
That's what I'm worried about! :lol::blush:
Any ideas what the torque settings are?? :)
found the Kinetix instructions on line here :thumbs:
http://www.350zfreak.com/plenum.htm
:thumbs:
I assume the gasket is reuseable then?? :wacko:
:thumbs:
yep , so long as you havent damaged it :thumbs:
There is some logic in that! I didn't give this much thought and am now worrying myself that I'm going to cause a load of damage!!
Will give it a go later. Is there a way of testing if there is an air leak when it is on?
i managed the kinetix no problem, just give your self an hour or so as there is a lot to take off and put back on, oh and dont loose any screws :teeth:
ps, hurry and send yours back to phil as its coming my way after that :thumbs:
drive it, if its leaking you will know ;)
Now that just sounds dangerous!! :surrender:
Thanks Trev and Paul. Will have a go tonight. Might even do my own guide on how to retrieve screws from cylinders 2 and 5!! :lol::blush:
Will get mine back out asap Paul. :thumbs:
You have a well lit garage then? Or will you be holding a pen light between your teeth? :lol:
Indeed I do! :thumbs:
Just about to give it a go..... :scare:
Its a doddle mate.
Had mine off and the new one on in a couple of hours and i did the plugs as well.
As soon as it is off put some clean rag on the inlet then dropping stuff is not an issue.
As for torque settings. I loosely fitted all the bolts and then slowly nipped down opposing bolts until it was nicely seated. Checked them a few days later and tightened them slightly. Re used the gasket no probs at all!!
Ming the Meddler
Well it is done. I will write it up with pictures later, but it's not too hard. The main concerns are making sure you can remove the 4 pipes from the plenum without damaging of breaking the retaining clips.
I currently have an erratic idle which I'm hoping by giving it a run out today will solve it.
Thanks for all your help and input guys. I did what you said Ming, lightly did all the bolts then nipped them up. I have a torque wrench, but it's lowest setting is 30 lb ft, so I didin't use it on this. The Kinetix instructions show even lower figures as it isn't as sturdy as the OEM one.
Pictures to follow...... :thumbs:
Edit - pics here - not great quality as taken by a muppet, in the dark, in a rush!
They don't do it justice at the moment. Will get some done in better conditions. :blush:
