Fastcar Magazine 350z boot install and audio SOLD
LewisL
SOLD
Hi Guys
Selling some of the audio setup from my car the fastcar magazine dream build 350z.
Selling the complete boot install with Genesis Amp and Kicker L7 sub. No other speakers or the head unit.
Basically the complete rear interior of the car is yours if you want it you can take as much or as little as you like. All the cabling you require to run the amp and sub is also yours if you want it.
Everything is still installed in the car so you can fully test it before you buy. However we will need a few hours to strip it all out or if you give me enough notice I can strip it out ready for you to take but I would want a non-refundable deposit to do that. Also I am more than happy to transfer out of my car into yours and get it all working bfore you leave, again would need some notice on this to make sure I put a day aside for you.
The amp, sub and install are all in show condition and perfect working order.
I am going a different way with the car(drifting) so making lots of space for roll cage and the ability to carry tyres!
The amp retails for £1600 and the sub for £300 plus then the cabling and whatever a professional boot install would cost you?
I have the amp on its own on eBay for £1000.
You guys can have everything for £1000 this is basically what the roll cage is going to cost me.
Took as best pics as I could also took pics of the magazine feature.
Any questions or you want different pics then call/txt/WhatsApp me on 07854843188
Here is the specs on the amp and sub:
Genesis Black Edition MK5 5 Channel Amp
4x90 + 1x450 watts RMS @ 4ohms
4x135 + 1x450 watts RMS @ 2ohns & 1ohm
2x275 watts RMS bridged @ 4ohms
Frequency - Adjustable EQ - 50hz - 40khz
Signal noise ratio 110db
THD + Noise @ Rated Output - 0.1%
Input Sensitivity[Volts RMS] 0.3~5
Weight[Kg] - 5.7
Height - 62mm
Width 500mm
Depth 240mm
http://www.madescc.com/large-gallery-genesis-mk5-blac/4580425375
Kicker L7 Sub Woofer
Rated Impedance [Ω]
2
Fs [Hz
34
Sensitivity [1W, 1m]
86.9
Qts
0.539
Qms
9.488
Qes
0.571
Re [Ω]
6.8
Vas [ft³, L]
1.92, 54.274
Continuous Power Handling [Watts RMS]
900
http://www.kicker.com/12-l7-subwoofer
DSC_0025_zps27nswzxk.jpg?w=480&h=480&fit=clip
DSC_0024_zps4i9f9kw4.jpg?w=480&h=480&fit=clip
DSC_0026_zpswlbri0aq.jpg?w=480&h=480&fit=clip
DSC_0029_zpsmlsjxj1f_edit_1446890996925_zpsxvzgymva.jpg?w=480&h=480&fit=clip
DSC_0028_zpsdb4x3zlt.jpg?w=480&h=480&fit=clip
DSC_0030_zps8rdxexkk.jpg?w=480&h=480&fit=clip
DSC_0032_zpsai2tn9wn.jpg?w=480&h=480&fit=clip
Cheers
Lewis
Edited by LewisL
  • 1 month later...
