What is tyre feathering/cupping?
Removed
These terms are used to refer to a specific type of undesirable front tyre wear on some 350zs. This problem occurred for many (but not a majority) of owners in the US and has been found in the UK as well.
The tyres wear unevenly on their outer (check) edge leading to roaring/rumbling/howling noise which gets worse as wear/mileage increases. Some owners have reported associated steering feel changes and even reduced front end grip.
Nissan GB now recognise that this condition can occur and will inspect tyres when the problem is reported. If they find that the problem is affecting a car, they will usually replace the tyres and reset the toe-in settings of the car to avoid the problem re-curring.
Replacement tyres have a different tread design and these have also been fitted as standard to new 350zs since some time in early 2004.
