jumping350 Posted October 23, 2015 Share Posted October 23, 2015 (edited) Ive had double rage today and its about to turn into triple rage with this oil cooler! Does anyone have an oil filter sandwich plate adapter bolt I could have (in london or Surrey area) I will replace with a mishimoto one next week but need it this weekend if possible Picture below Typically I have 3 of them all m20 x 1.5 but only one works (middle one) Edited October 23, 2015 by jumping350 Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted October 23, 2015 Share Posted October 23, 2015 (edited) If it's length your having trouble with, you can cut them down a bit. I had to do it in the past when the bolt is too long and it doesn't clamp the sandwich plate tight. Edited October 23, 2015 by Sam Mcgoo Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 23, 2015 Author Share Posted October 23, 2015 Thanks Sam, that's not the current problem but im sure that will rear its head after i sort this one out! The silver adapter above is the mocal one which works, the other two fit below it but wont screw into thread above, I suspected this would be the same on the engine and when I got there low and behold it wouldn't screw onto engine thread, mocal one went on with ease so both gold ones are no good even though the right metric etc 1 Quote Link to comment Share on other sites More sharing options...
gsexr Posted October 23, 2015 Share Posted October 23, 2015 (edited) this lot may be able to help and they are in london mate http://www.middxhose...dxhose_244.aspx Or http://www.burtonpower.com/ Depends where in london you are Edited October 23, 2015 by gsexr Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 23, 2015 Author Share Posted October 23, 2015 (edited) Thanks gsexr, il check them out, dont care london is london at this point I just want a bloody adapter Edited October 23, 2015 by jumping350 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted October 23, 2015 Share Posted October 23, 2015 I might have a spare one somewhere in my spare boxes at RTP. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 23, 2015 Author Share Posted October 23, 2015 You are amazing if you do mate, when would you know? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted October 23, 2015 Share Posted October 23, 2015 Fancy coming down later this evening, traffic is mad now on A406 Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 23, 2015 Author Share Posted October 23, 2015 hi mate sorry popped out at the moment, did you have one? Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted October 23, 2015 Share Posted October 23, 2015 Found this one at home Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 23, 2015 Author Share Posted October 23, 2015 (edited) I knew i shouldnt of gone out. today is officially the day of rage Il drop you a message tommorow if your around Edited October 23, 2015 by jumping350 Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 25, 2015 Author Share Posted October 25, 2015 (edited) so the rage continues....... Managed to get hold of another sandwich plate adapter and even better it is shorter than the Mocal one So that should avoid the problem Sam pointed out right??................Wrong!! Sandwich plate ends up right against the block but can spin it round with my finger so its literally 1 two threads shy...I cant cut the threads because its on the engine block If I were to put a couple of stainless steel washers between the sandwich plate and the sandwich plate adapter where it meets that should space it enough to tighten and clamp the sandwich plate down, will this be ok to do?? It would need a m22 washer which no one appears to sell in a shop on a Sunday so I cant finish it today.... the rage continues........ Edited October 25, 2015 by jumping350 Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 25, 2015 Author Share Posted October 25, 2015 and now my stupid Veilside holes and intercooler pipes are in the way to fit the oil cooler...ahhhhhhhhhh Should i bring the angle grinder out to cut the holes this weekend?? I think il save it for another day Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 27, 2015 Author Share Posted October 27, 2015 just a small update in my oil cooler woes, found a sandwich plate washer you can put in between the plate and adpater to space it out, just hoping it doesnt space it out enough to then effect the Mocal one Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 29, 2015 Author Share Posted October 29, 2015 here is said spacer in between sandwich plate and adapter, off the car fitment seems it will do the job and gives me quite a few more threads than before Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 30, 2015 Author Share Posted October 30, 2015 (edited) went out for a test fit and it now tightens on and first sandwich plate doesnt move Luckily it seems to Mocal plate will tighten without adding anything else...and more importantly the oil lines/fittings clear and one with the oil filter on for good measure, I destroyed my K&N filter getting it off that stupid nut on the end doesnt help at all and its a weird size which I dont have went to halfords twice to get the right spanner still didnt budge it just kept slipping off Overall should be ok but I hand tightened so wont really know until I go and tighten everything down properly on Sunday...once and for all Edited October 30, 2015 by jumping350 Quote Link to comment Share on other sites More sharing options...
