Mikey Thompson Posted October 21, 2015 Share Posted October 21, 2015 As the title says really but a bit of history: Bought the car ('04 with GT pack) from a small town dealer in January, noticed that when I lock the car and try to open the passenger door, it pops open. Now, the door could not be opened fully, it just went to the point where it sits when you don't shut it properly (about 1cm open). After haggling the price to factor this in, got it home, sprayed GT85 around the mechanism which solved the problem for a good 4-5 month. After this, the problem then became intermittent. Now, this evenings discovery is that when I now try the passenger handle after locking the car, the door opens fully?! Also, ever since I bought the car the passenger door could not be locked/unlocked using the button on the interior handle. Electric button on drivers door worked fine, but the manual one on the passenger handle does not budge at all. Would appreciate any immediate help with this as obviously my door can be opened at all times! Quote Link to comment Share on other sites More sharing options...
Mikey Thompson Posted October 23, 2015 Author Share Posted October 23, 2015 Anyone? Quote Link to comment Share on other sites More sharing options...
Ekona Posted October 23, 2015 Share Posted October 23, 2015 Have you popped the door card off to take a look? Quote Link to comment Share on other sites More sharing options...
Mikey Thompson Posted October 23, 2015 Author Share Posted October 23, 2015 Not yet, was hoping someone could give me some idea of what I should be looking for once it's off? Quote Link to comment Share on other sites More sharing options...
Ricey Posted October 23, 2015 Share Posted October 23, 2015 Almost the exact same problem on a Xsara I'm working on today. One of the rods had become detached because the mechanism had seized up and generally was buggered. You might be lucky and a rod has become detached but it could be the mechanism has worn to the point where something isn't returning properly. You need to take the door card off and probably drop the latch mechanism out but it'll be a sod of a job if this one is anything to go by! Make sure you carefully note where all rods, pins and leavers line up to Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 23, 2015 Share Posted October 23, 2015 Almost the exact same problem on a Xsara I'm working on today. One of the rods had become detached because the mechanism had seized up and generally was buggered. You might be lucky and a rod has become detached but it could be the mechanism has worn to the point where something isn't returning properly. You need to take the door card off and probably drop the latch mechanism out but it'll be a sod of a job if this one is anything to go by! Make sure you carefully note where all rods, pins and leavers line up to Take pictures as you go. Quote Link to comment Share on other sites More sharing options...
