Drivers side window switches trim
Mikeymike7
Is yours snapped or are the clips broken, or is it just scuffed?
99% of the forum gave up with that horrible textured stuff and just sprayed it ourselves with rattle cans, or get them dipped in fancy finishes. I myself did the latter and got carbon fiber effect done :)
Otherwise I can't help you buddy, cause I'm not sure why you are after new ones.
There are a few videos and threads out there on how to pop them out.
All you need is a screw driver or two AND PRYING TOOLS.
They help so much. They are mounted differently in a pre and post facelift as I found out the hard way. Make sure you have the right instructions.
Basically you can just sand them smooth, get the old rattle cans out and go mad. Easy to do and cheap fix.
