R88RPE Posted October 11, 2015 Share Posted October 11, 2015 Hello. My airbag light is constantly flashing on the car now, the pattern is one short flash followed by two long flashes. Can anyone help me find out what this code means? Many thanks! Quote Link to comment Share on other sites More sharing options...
R88RPE Posted October 11, 2015 Author Share Posted October 11, 2015 I forgot to mention I have used the airbag light reset procedure and it just comes straight back Quote Link to comment Share on other sites More sharing options...
Gudzy Posted October 11, 2015 Share Posted October 11, 2015 Check if there is anything under the seats that might have disturbed the connections. Disconnect the plastic connectors under the seats, reconnect them and then do the reset procedure again. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 11, 2015 Share Posted October 11, 2015 Try disconnecting the battery for 30 minutes, however you really need to get a code to sort this if it is not a loose connection, so a better procedure is to find out what codes are present before clearing them. Instead of turning the key off the fourth time, leave it on. A different blink pattern will appear and tell you which unit or units the diagnostic unit thinks are at fault. These patterns are shown in the Service Manual beginning on page SRS-34. Alex. Quote Link to comment Share on other sites More sharing options...
R88RPE Posted October 11, 2015 Author Share Posted October 11, 2015 I can't find the codes in the service manual. I'll have to wait till I have access to a pc instead of my tiny bloody phone screen! Thanks guys Quote Link to comment Share on other sites More sharing options...
R88RPE Posted October 11, 2015 Author Share Posted October 11, 2015 Would someone be able to help me identify this code please? https://youtu.be/rdrm4SHoAOM Quote Link to comment Share on other sites More sharing options...
R88RPE Posted October 11, 2015 Author Share Posted October 11, 2015 Fixed the issue. I contacted a Nissan mechanic I know and he told me to cut the plugs off airbag wires under the drivers seat and solder them together. Apparently they cause a resistance Quote Link to comment Share on other sites More sharing options...
HEADPHONES Posted October 11, 2015 Share Posted October 11, 2015 If that doesn't work it could be the clock spring airbag thingy behind the steering wheel. Had mine fail earlier this year. An independent may be able to source a 2nd hand one and fit for around £100 Quote Link to comment Share on other sites More sharing options...
