Little74 Posted October 9, 2015 Share Posted October 9, 2015 Ok so I have a few small areas of rust trying to pop out mainly wheel arch area what can I do to stop or correct because a paint will be a short term Bury my head in the sand fix any idea be great thanks Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 9, 2015 Share Posted October 9, 2015 (edited) You could try using some "Kurust" in the short term to attempt to stop the rust spreading too far (as pictured below) but ultimately the only way to get rid of rust is to have the affected panels/areas taken back to bare metal & repainted or in a worst case scenario the rust would need to be cut out or the entire panel replaced. Edited October 9, 2015 by GMballistic Quote Link to comment Share on other sites More sharing options...
T-Bear Posted November 9, 2015 Share Posted November 9, 2015 Oxalic acid is great for removing surface rust. Those little dots of rust, gone You tube how to use. costs pennies. Quote Link to comment Share on other sites More sharing options...
R88RPE Posted November 9, 2015 Share Posted November 9, 2015 It usually starts at the rear of the panel that you can't get to anyway Quote Link to comment Share on other sites More sharing options...
