Jeff king Posted October 9, 2015 Share Posted October 9, 2015 This seems to happen when pulling off in 1st and also from accelerating in 2nd but only in the early stages of acceleration. Any ideas what this could be? Quote Link to comment Share on other sites More sharing options...
Sargara Posted October 9, 2015 Share Posted October 9, 2015 (edited) I'd take everything out of the boot for starters to eliminate something rolling around. Edit: To clarify, I mean from under the carpet where the tools are located. Edited October 9, 2015 by Sargara Quote Link to comment Share on other sites More sharing options...
Jeff king Posted October 9, 2015 Author Share Posted October 9, 2015 Thanks sargara I'll try that although it does seem as though it's more chassis bound. Not sure if it may be something to do with the exhaust. Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted October 9, 2015 Share Posted October 9, 2015 (edited) It'll be the heat shield on your exhaust rusting away. I had the same. The area around one the fixing bolts had rusted on mine and it was flapping away. I took the bolt out and stuck a massive washer on it! Edited October 9, 2015 by Randy_Baton Quote Link to comment Share on other sites More sharing options...
Gudzy Posted October 9, 2015 Share Posted October 9, 2015 Clicking rear axles perhaps? Quote Link to comment Share on other sites More sharing options...
Oggieteepo Posted October 9, 2015 Share Posted October 9, 2015 I got this or something similar, I can't figure it out and have my whole rear end and suspension off at the moment because of it, Kind of sounds like a bag of 4 coins rattling twice when I accelerate away in a ching ching fashion so sounded like a loose joint or something for knocking back and fourth. Its definitely an exterior noise rather than interior/boot. I had an aftermarket exhaust on mine so I don't think the heat shield applies to me.. (Japspeed K1) Quote Link to comment Share on other sites More sharing options...
Jeff king Posted October 9, 2015 Author Share Posted October 9, 2015 Hmm, not sure I'm ready to start taking my car to bits just yet as its my daily. I've only had the car a couple of days and I have very limited knowledge about them I.e none. I know it has a cobra resonated exhaust on it so not sure if the heat shield thing applies to me too but I'll probably start with having a look underneath for it anyway. Where would it be exactly? Quote Link to comment Share on other sites More sharing options...
Jeff king Posted October 9, 2015 Author Share Posted October 9, 2015 I hope not as that problem was apparently resolved by previous owner Quote Link to comment Share on other sites More sharing options...
Gudzy Posted October 9, 2015 Share Posted October 9, 2015 Do you know if the parts were replaced or just greased? Quote Link to comment Share on other sites More sharing options...
Jeff king Posted October 9, 2015 Author Share Posted October 9, 2015 Just checked history and it was in with Nissan. Invoice says (replace rear outer driveshaft joints and bearings) Bearing-rear ax Housing slide Bearing-rear ax Repair kit-dust Looks like this was in 2007. The car is 2004 model. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 9, 2015 Share Posted October 9, 2015 Have you checked the condition of the rear exhaust back box? What about the heat shield above the exhaust back box? Lot's of things that could cause a "rattly" sound tbh. Also it might actually be happening in higher gears too but with the increased road noise/tyre noise/wind noise etc it may not be as easy to hear, ...just a thought. Quote Link to comment Share on other sites More sharing options...
KyleR Posted October 9, 2015 Share Posted October 9, 2015 Clicky Axel? Quite a common problem on 350Z's, I've never heard it myself, so not sure if it could be mistaken for a rattle. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted October 10, 2015 Share Posted October 10, 2015 rear heatshield Quote Link to comment Share on other sites More sharing options...
Oggieteepo Posted October 10, 2015 Share Posted October 10, 2015 (edited) On 09/10/2015 at 23:55, KyleR said: Clicky Axel? Quite a common problem on 350Z's, I've never heard it myself, so not sure if it could be mistaken for a rattle. Yeah, When I listened to recordings of the clicky axle but mine was completely different, I have not disregarded it however. I'm going to do the grease 'fix' on here whilst I have it apart, but I have to get a new socket as I have everything but. I will let you know if I get any improvements, I have also changed my drop links, diff oil change, and a lot of cleaning components, will be putting a new zorst on there too but ultimately won't be able to pin point what worked exactly... Edited October 10, 2015 by Oggieteepo Quote Link to comment Share on other sites More sharing options...
Jeff king Posted October 10, 2015 Author Share Posted October 10, 2015 I wish I had more spare time on my hands although it wouldn't be spare cos it would be all used up on the zed Quote Link to comment Share on other sites More sharing options...
KyleR Posted October 10, 2015 Share Posted October 10, 2015 Click it on a ramp and go round under it tapping various bits with a hammer? Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted October 11, 2015 Share Posted October 11, 2015 On 09/10/2015 at 15:55, Jeff king said: Hmm, not sure I'm ready to start taking my car to bits just yet as its my daily. I've only had the car a couple of days and I have very limited knowledge about them I.e none. I know it has a cobra resonated exhaust on it so not sure if the heat shield thing applies to me too but I'll probably start with having a look underneath for it anyway. Where would it be exactly? I've got the same exhaust so I'm still thinking it's the heat shielding Quote Link to comment Share on other sites More sharing options...
ts743 Posted October 12, 2015 Share Posted October 12, 2015 Jeff - This is normal, it's a single mass flywheel Quote Link to comment Share on other sites More sharing options...
Ebized Posted October 12, 2015 Share Posted October 12, 2015 Merged second thread here, tided and deleted posts. 1 Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted October 12, 2015 Share Posted October 12, 2015 (edited) On 09/10/2015 at 19:15, GMballistic said: What about the heat shield above the exhaust back box? This. Stick your head and arm under the back end and give the heat shield a wiggle. Edited October 12, 2015 by Toon Chris Quote Link to comment Share on other sites More sharing options...
FiddyZed Posted October 13, 2015 Share Posted October 13, 2015 How weird is this - I wasn't sure if it was just me but I seem to be getting this same noise - it sounds like the exhaust or something around the exhaust and only happens when I'm in first or second accelerating / decelerating. I have a Japspeed, will try and get underneath and wiggle bits around and see where its coming from! Quote Link to comment Share on other sites More sharing options...
Oggieteepo Posted October 14, 2015 Share Posted October 14, 2015 Interestingly enough I also had a Japspeed, it's off the car now but nothing rattling on the exhaust itself. It won't be going back on, and whilst I had the wheels off I did the grease clicky axle fix on one side too so fingers crossed. Quote Link to comment Share on other sites More sharing options...
Jeff king Posted October 14, 2015 Author Share Posted October 14, 2015 On 12/10/2015 at 12:25, ts743 said: Jeff - This is normal, it's a single mass flywheel Quote Link to comment Share on other sites More sharing options...
Jeff king Posted October 14, 2015 Author Share Posted October 14, 2015 Hi tom, thanks but the sound does seem to be coming from the back of the car. Sounds like a vibration around the exhaust area.. P.S. Loving the car ðŸ‘🻠Quote Link to comment Share on other sites More sharing options...
ts743 Posted October 14, 2015 Share Posted October 14, 2015 On 14/10/2015 at 08:13, Jeff king said: Hi tom, thanks but the sound does seem to be coming from the back of the car. Sounds like a vibration around the exhaust area.. P.S. Loving the car í ½í±í ¼í¿» Ah okay, just thought it odd as it's never so much as hinted at a rattle - the exhaust system is pretty new etc and the SMF has always proved quite rattly and loud pulling away at low RPM. Hope you get it sorted and glad you're enjoying zed ownership! Quote Link to comment Share on other sites More sharing options...
