Quinster Posted October 3, 2015 Share Posted October 3, 2015 There's two small buttons next to the Snow/Power button. I've no idea what they are for? When i push them nothing happens at all (nothing i can see) lol Anyone know what they do? One of them has a small design on it as well. Quote Link to comment Share on other sites More sharing options...
davetstan Posted October 3, 2015 Share Posted October 3, 2015 Heated seats Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Quinster Posted October 3, 2015 Author Share Posted October 3, 2015 Heated seats Sent from my iPhone using Tapatalk Seriously? Never even knew i had heated seats. Shame it's not the mirrors if i'm honest. Winter mornings are a bummer. lol Which button does what? Quote Link to comment Share on other sites More sharing options...
davetstan Posted October 3, 2015 Share Posted October 3, 2015 The mirrors should be heated to from memory. The button nearest the drivers seat heats the bit you sit on only not the back rest. Turn it on, when it feels like you have soiled yourself it's done it's job 😄 Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Quinster Posted October 3, 2015 Author Share Posted October 3, 2015 The mirrors should be heated to from memory. The button nearest the drivers seat heats the bit you sit on only not the back rest. Turn it on, when it feels like you have soiled yourself it's done it's job í ½í¸„ Sent from my iPhone using Tapatalk Thanks. Is there a button for the mirrors too? p.s this is great finding out all these things. lol Quote Link to comment Share on other sites More sharing options...
Wayne370Z Posted October 3, 2015 Share Posted October 3, 2015 If it`s the same as on the 370 the heated mirrors come on with the heated rear screen. 2 Quote Link to comment Share on other sites More sharing options...
Quinster Posted October 3, 2015 Author Share Posted October 3, 2015 If it`s the same as on the 370 the heated mirrors come on with the heated rear screen. Thanks, I'll try it out in the morning. Quote Link to comment Share on other sites More sharing options...
a2orry Posted October 4, 2015 Share Posted October 4, 2015 Yep mirrors heat with rear screen demist on. 1 Quote Link to comment Share on other sites More sharing options...
mdunbar Posted October 4, 2015 Share Posted October 4, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? 2 Quote Link to comment Share on other sites More sharing options...
PPod Posted October 4, 2015 Share Posted October 4, 2015 ^^^ nitrous option, 2005 upwards had it added. 3 Quote Link to comment Share on other sites More sharing options...
Quinster Posted October 4, 2015 Author Share Posted October 4, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Not sure but on mine (import) it's a Snow/Power button. Probably the same as yours. Only down side is, i keep knocking it onto snow when i stop at lights etc. Pulls away slowly all the time. Need to knock it into neutral and then switch it off. Quote Link to comment Share on other sites More sharing options...
Quinster Posted October 4, 2015 Author Share Posted October 4, 2015 ^^^ nitrous option, 2005 upwards had it added. You bad man. lol 1 Quote Link to comment Share on other sites More sharing options...
M1 6RYF Posted October 4, 2015 Share Posted October 4, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Not sure but on mine (import) it's a Snow/Power button. Probably the same as yours. Only down side is, i keep knocking it onto snow when i stop at lights etc. Pulls away slowly all the time. Need to knock it into neutral and then switch it off. Am i right in thinking that is only on automatics. Otherwise it is blank Quote Link to comment Share on other sites More sharing options...
mdunbar Posted October 4, 2015 Share Posted October 4, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Not sure but on mine (import) it's a Snow/Power button. Probably the same as yours. Only down side is, i keep knocking it onto snow when i stop at lights etc. Pulls away slowly all the time. Need to knock it into neutral and then switch it off. Snow button? I drove a 350Z in the snow when I first owned one ten years ago and if that button works it would keep the doors locked and not let you get in The only snow button in a UK spec car is the traction control - better switch it off in the snow to avoid getting stuck... if you haven't already met a sticky end that is... Quote Link to comment Share on other sites More sharing options...
mdunbar Posted October 4, 2015 Share Posted October 4, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Not sure but on mine (import) it's a Snow/Power button. Probably the same as yours. Only down side is, i keep knocking it onto snow when i stop at lights etc. Pulls away slowly all the time. Need to knock it into neutral and then switch it off. Am i right in thinking that is only on automatics. Otherwise it is blank Ah, that might be it... 1 Quote Link to comment Share on other sites More sharing options...
Quinster Posted October 4, 2015 Author Share Posted October 4, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Not sure but on mine (import) it's a Snow/Power button. Probably the same as yours. Only down side is, i keep knocking it onto snow when i stop at lights etc. Pulls away slowly all the time. Need to knock it into neutral and then switch it off. Am i right in thinking that is only on automatics. Otherwise it is blank Ah, that might be it... I never mentioned it was an automatic. It has Traction control as well. Quote Link to comment Share on other sites More sharing options...
M1 6RYF Posted October 4, 2015 Share Posted October 4, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Not sure but on mine (import) it's a Snow/Power button. Probably the same as yours. Only down side is, i keep knocking it onto snow when i stop at lights etc. Pulls away slowly all the time. Need to knock it into neutral and then switch it off. Am i right in thinking that is only on automatics. Otherwise it is blank Ah, that might be it... I never mentioned it was an automatic. It has Traction control as well. Is it a manual then? http://www.350z-uk.com/topic/16915-snowatpower-button-whats-it-do/ Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted October 5, 2015 Share Posted October 5, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Think your missing the roof down button Quote Link to comment Share on other sites More sharing options...
Quinster Posted October 5, 2015 Author Share Posted October 5, 2015 My car, a 2003 UK GT spec, has a blanked out button closest to the driver next to the heated seats switches. What option am I missing? Think your missing the roof down button My roof button is on my right, next to the steering wheel. Quote Link to comment Share on other sites More sharing options...
