matt3579 Posted January 30, 2017 Author Share Posted January 30, 2017 and the final piece of the puzzle is the spoiler, so a couple drive down the Devon way to pick it up off a fellow member, all nice ready shaped with carbon blade just needs paint fyi to anyone picking one up it on just fit in the back of my fn2 civic so i wouldnt pick one up in a corsa, needs to dry then i can clear coat it and ready to fit it 1 Quote Link to comment Share on other sites More sharing options...
matt3579 Posted January 30, 2017 Author Share Posted January 30, 2017 On 30/01/2017 at 15:07, valy said: looks good I see you went for the version without the arches which is nice too fitment looks spot on...keep the pics coming thanks does have the archs on tho but yer it does look nice without but had to do the whole lot, tho had i been told how much of a pain it is i may have stopped and left it without them.... its getting there got the front passenger arch left half to get on and spoiler, the drivers rear by the petrol cap needs a fair bit of taking out sadly ... another couple weeks should be a done job Quote Link to comment Share on other sites More sharing options...
lmc Posted January 30, 2017 Share Posted January 30, 2017 Looking good mate. Just wheels to go? Quote Link to comment Share on other sites More sharing options...
valy Posted January 30, 2017 Share Posted January 30, 2017 On 30/01/2017 at 15:15, matt3579 said: On 30/01/2017 at 15:07, valy said: looks good I see you went for the version without the arches which is nice too fitment looks spot on...keep the pics coming thanks does have the archs on tho but yer it does look nice without but had to do the whole lot, tho had i been told how much of a pain it is i may have stopped and left it without them.... its getting there got the front passenger arch left half to get on and spoiler, the drivers rear by the petrol cap needs a fair bit of taking out sadly ... another couple weeks should be a done job what are you planing to use in between the arches and the car...a 3m weathershield strip or something similar?also what did you use to extend the splash guards? Quote Link to comment Share on other sites More sharing options...
lmc Posted January 30, 2017 Share Posted January 30, 2017 On 30/01/2017 at 15:33, valy said: On 30/01/2017 at 15:15, matt3579 said: On 30/01/2017 at 15:07, valy said: looks good I see you went for the version without the arches which is nice too fitment looks spot on...keep the pics coming thanks does have the archs on tho but yer it does look nice without but had to do the whole lot, tho had i been told how much of a pain it is i may have stopped and left it without them.... its getting there got the front passenger arch left half to get on and spoiler, the drivers rear by the petrol cap needs a fair bit of taking out sadly ... another couple weeks should be a done job what are you planing to use in between the arches and the car...a 3m weathershield strip or something similar?also what did you use to extend the splash guards? If your on about extending the inner plastic arches what i did with my rx7 was to get a roll of 2mm abs plastic of ebay. It molds really easy with heat then i just used an industrial stapler to fix to existing arch. 1 Quote Link to comment Share on other sites More sharing options...
matt3579 Posted January 30, 2017 Author Share Posted January 30, 2017 the bottom of the arch has the bases molded on ive only had to cut one off but im going to be shaping one over it to fit. im thinking just gonna get some wheel archs from the scrap yard any ones will do then basically cut and melt them together, or something along those lines so it can carry on sitting in the arch and wrap round. Quote Link to comment Share on other sites More sharing options...
matt3579 Posted January 30, 2017 Author Share Posted January 30, 2017 On 30/01/2017 at 15:18, lmc said: Looking good mate. Just wheels to go? thanks yer seen some but a bit of saving to do first might just have to see if anything cheap comes up first tho Quote Link to comment Share on other sites More sharing options...
Payco Posted January 30, 2017 Share Posted January 30, 2017 Looking good but the Rays have to go now for some deep dish 19's. Quote Link to comment Share on other sites More sharing options...
matt3579 Posted February 10, 2017 Author Share Posted February 10, 2017 ok so took a break from the body kit for a couple days, if the outside looks sexy the inside should match, sadly i dont think veilside do a wide body center console so i decided to dip it instead i wasnt to sure about painting the gauge rings blue though even when they were done right upto the point i fitted them into the finsihed pods then i fell in love its just subtle enough to look sexy like stocking on a pair on long legs Quote Link to comment Share on other sites More sharing options...
matt3579 Posted February 10, 2017 Author Share Posted February 10, 2017 the days past and paint dried and ive had to wait for a dry day to come round to fit the finished spoiler drilled to holes in the boot and started snowing.... bull s**t weather but carried on anyway fitting the spoiler not the easist job by yourself mainly due to the size of it and lining it up could get both sides to stay put it was either one of the other so drilled a hole in either side and put a rivet in either side to hold the (dunno what you call them but the long bits that sit up the boot) do dads on and screwed it in through the holes i made earlier some tiger seal and and job is a gooden Quote Link to comment Share on other sites More sharing options...
matt3579 Posted February 10, 2017 Author Share Posted February 10, 2017 cheeky veilside sticker as the back was looking a bit blank Quote Link to comment Share on other sites More sharing options...
matt3579 Posted March 5, 2017 Author Share Posted March 5, 2017 so as time goes by got a bit more done now have both the front archs painted and fitted and very happy with how it looks just a few small bits and bobs to do now, then the drivers rear arch to fit now its all painted as i had to take it off to sort the fuel filler cap out. Quote Link to comment Share on other sites More sharing options...
matt3579 Posted March 5, 2017 Author Share Posted March 5, 2017 i quite fancy fitting some fog lights or something along those lines in the holes in the front if any knows or anything that may fit or have has fitted some and a guide on how to fit them would be good Quote Link to comment Share on other sites More sharing options...
matt3579 Posted March 15, 2017 Author Share Posted March 15, 2017 well its taken far longer than i had first hoped but she is now done, i give you a fully kitted v3 veilside 350z (minus wheels really need bigger ones) gave her a wash too where shes been sat infront of the garage the front end has some overspray but nothing a polish and claybar wont sort out over the weekend "shes a beast i call her karma" Quote Link to comment Share on other sites More sharing options...
xscotteex Posted March 17, 2017 Share Posted March 17, 2017 Wide arch kits without correct fitment always make me chuckle Are you going for a fat dish or just big ass offset? Quote Link to comment Share on other sites More sharing options...
matt3579 Posted March 20, 2017 Author Share Posted March 20, 2017 bit of both small dish with about 0 offset Quote Link to comment Share on other sites More sharing options...
matt3579 Posted April 16, 2017 Author Share Posted April 16, 2017 now for sale if anyones intrested £8500 of close offers Quote Link to comment Share on other sites More sharing options...
da.murf Posted April 17, 2017 Share Posted April 17, 2017 Didn't see that coming lol, nice example and was looking forward to seeing wheels on the kit. Why the change? Something special in the pipeline? Quote Link to comment Share on other sites More sharing options...
matt3579 Posted April 18, 2017 Author Share Posted April 18, 2017 i was hoping for some big wheels too if some come up for the right price ill still get them on but coming into some money in the not so distant future so between selling this and that gonna shell out and get a 34 gtt and get the gtr kit on it Quote Link to comment Share on other sites More sharing options...
matt3579 Posted July 4, 2017 Author Share Posted July 4, 2017 ok so had a slight change of heart was going to sell but i think i may have found my love for it again i blame daily cars and winter, i fall out of love with this till i get in and drive it properly, so i pulled up a kirb and the front mounted it and somewhat cracked my archs on the front so ive had to take them off fibreglass and filler but im thinking im gonna go black with the body kit (archs and skirts only) you can see where this is going .... im gonna blot the archs on rather than rivet for the time being leave it black and blue for a month or as got a few shows coming up so its gonna be a bit rough but nevermind, then when all shows are done and it can come off the road for a few weeks im thinking grey for the body stealth matt grey to be precise, those who know, know, those who dont you will when you see it. 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted August 10, 2017 Share Posted August 10, 2017 Still have my 20" Ascari deep dish wheels with New tyres and spacers off my wide body Veilside if you want. £1200 takes it all 1 Quote Link to comment Share on other sites More sharing options...
matt3579 Posted August 10, 2017 Author Share Posted August 10, 2017 nar I'm good but thank you anyway Quote Link to comment Share on other sites More sharing options...
sketch Posted October 21, 2017 Share Posted October 21, 2017 Desperatly needs wheels Quote Link to comment Share on other sites More sharing options...
