Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 Dragging up this issue again ... need to bounce thoughts off someone ... Have got front end knock at low speeds ... The usual pain in the arse undiagnosable problem ... Both droplinks replaced ... no improvement ... banana arms next ... is it worth replacing just bushes first or should I bite the bullet and get the arms and bushes etc replaced in totality ? I keep going back and forth on it in my head ... reason being is that next month is going to be expensive as I am buying ark grip exhaust ... replacing the roof with mohair ... replacing a door card ... getting some other bits sorted and paying off a credit card on top of the usual mortgage blah blah ... so I need to make the right decision both for the car and my wallet ... seems to me that I would be double handling the problem and paying more overall if I get the bushes replaced and his does not solve the problem (is that even a likely outcome ??) .... There again it would be alot cheaper to replace the bushes than do the whole lot ... Any opinions would be appreciated ... no sympathy expected Marc Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
mikejbry Posted September 26, 2015 Share Posted September 26, 2015 Well if you replace the bushes on their own, you have to worry that your ball joints aren't far behind, which requires a new arm anyway.... Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 Yeah ... im kinda thinking that might be the case ... saves doubling up on labour charges ... poor old bank balance .... Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stutopia Posted September 26, 2015 Share Posted September 26, 2015 (edited) I just bit the bullet and had the whole arm done. If you do the bush, it's bound to be the ball joint. Edited September 26, 2015 by SuperStu Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 (edited) Thanks Stu .... would ZMANALEX be the guy to get in touch with for parts ? I am going to get the super pro caster adjustable kit for the bushes so I need the arms, cone and any other bits ... Sent from my SM-G900F using Tapatalk Edited September 26, 2015 by marcw79 Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted September 26, 2015 Share Posted September 26, 2015 (edited) Bite the bullet ! ... It'll be like a new car Edited December 19, 2015 by ATTAK Z Quote Link to comment Share on other sites More sharing options...
gillywig2 Posted September 26, 2015 Share Posted September 26, 2015 (edited) Also check the lower control arms. These were the culprit for my knocking. Edited September 26, 2015 by gillywig2 Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 Thanks gillywig2 ill be sure to have that checksed though I have had a bunch of guys check everything with pry bars etc ... as usual no joy though ... Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Piranha Posted September 26, 2015 Share Posted September 26, 2015 Also check the lower control arms. These were the culprit for my knocking. +1 for this suggestion, just done the bushes in my lower arms as they were split. Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 Cheers guys ... I'll be sure to ask them to recheck those too ... Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Sargara Posted September 26, 2015 Share Posted September 26, 2015 At least replacing the whole arm gives you a spare set of arms that will come off your car, you can always try replacing the bushes in those for "next time" at a later date Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 Not a bad idea ... hoping that with the super-pro bushes there won't be a next time ... but certainly worth considering :-) Sent from my SM-G900F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Sargara Posted September 26, 2015 Share Posted September 26, 2015 (edited) Not a bad idea ... hoping that with the super-pro bushes there won't be a next time ... but certainly worth considering :-) Sent from my SM-G900F using Tapatalk That's my plan. About to shell out £500 for the same thing (new arms) in about 2 weeks time Edited September 26, 2015 by Sargara Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 Well I've always been of the opinion that stuff should be "done right and done once" ... even if it costs more to start with ... so many people (my clients included) seem to struggle with that and elect to go with a false economy ... though I also get in the sh*t with my better half for spending too much too ... Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted September 26, 2015 Share Posted September 26, 2015 Have you tried left foot braking whilst driving slowly over your favourite bumpy surface ? If the knocking stops (because the banana bar will definitely be in compression at this point) then it's 99 to 1 that it's the ball joint not the bushes Also can you tell which side the noise is coming from ? ... for some reason it's usually LHS first Quote Link to comment Share on other sites More sharing options...
Jack wellZ Posted September 26, 2015 Share Posted September 26, 2015 I bit the bullet and did the whole arm thankfully it was just the left hand side one did front and rear droplinks the other weekend as they bought back the knocking *sigh* but now all is silent again except for the exhaust welcome to owning a ark grip it's lovely! Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 (edited) I bit the bullet and did the whole arm thankfully it was just the left hand side one did front and rear droplinks the other weekend as they bought back the knocking *sigh* but now all is silent again except for the exhaust welcome to owning a ark grip it's lovely! Yeah ... can't wait for the exhaust ... am going to have a listen to humpy's tomorrow ... may end up adding berk hfc's I suspect Sent from my SM-G900F using Tapatalk Edited September 26, 2015 by marcw79 Quote Link to comment Share on other sites More sharing options...
Guest marcw79 Posted September 26, 2015 Share Posted September 26, 2015 Have you tried left foot braking whilst driving slowly over your favourite bumpy surface ? If the knocking stops (because the banana bar will definitely be in compression at this point) then it's 99 to 1 that it's the ball joint not the bushes Also can you tell which side the noise is coming from ? ... for some reason it's usually LHS first Thanks for that ... im out in the zed tomorrow so will give that a go and see what happens :-) can't tell which side .. may be both ... The guy who owned it before me didn't give a shi* about the car so there are masses of problems with it and so both sides wouldn't surprise me ... Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
GreenLandy Posted September 28, 2015 Share Posted September 28, 2015 I'd always do the bushes first - a knowledgeable garage can do the whole job in 45 mins, so labour isn't really an issue Quote Link to comment Share on other sites More sharing options...
