Coilover set up ?
Kaveney
Ok I have just ordered some Coilovers but have never had any dealings with them before so this will be my first time .
Installing them will be no problem as I have replaced the shock and spring before on the car in the last few months so know all that .
The bit im unsure about is the ride height and the spring pre load etc .
How is the ride height set and adjusted .
Regards
Alan
Won't be a straight fit if they're rear true coilover design. Have a look here: http://www.cyberspee...products_id=212
You need the rear toe arms with them too as you're getting rid of the OEM mid links where the spring holders is.
Look here: http://www.splparts.com/spl-titanium-rear-toe-links-350z-g35/
Edited by octet@TORQEN
http://www.350z-uk.com/topic/55218-meisterr-zeta-r-coilovers-for-sale-500-sold/
That post there would indicate to me that they're not true coilovers. However, if Meister R have changed their design since then, that would explain that. I assume you have them in hand?
You will need to beef up the rear subframe around the mounting points of the coilovers on the rear IF you are converting to true dual. Not something to be undertaken lightly.
No not that set up that is the Zeta S I have the Zeta R and have read about beefing up the rear mount .
Some people have and others have not and have been fine .
I think this rear bar is to take up some of the load that losing the inboard rear spring does .
http://www.hardrace.co.uk/nissan-350z-adj-rear-lower-arm-change-the-shock-to-1pc-dei.html
