Think I've made an expensive mistake !
Bodyboarder81
Removed both my throttle bodies to send to mopedmark to get polished ..... Thought I'd give them a good clean before I sent them , so did and manually moved the butterflies to clean ...... Now stumbled across a few threads saying this is not good :(
Will they be ok ?
I disconnected the battery before removal but have moved the butterflies by hand , is there anyway to undo what I've done ?
Thanks for your help
Update .......
All is ok !!!!
Recieved the throttle bodies back from Mr moped mark ..... Fitted and no issues what so ever :)
Actually not completely true ..... I forgot to connect on of the throttle bodies wiring clip ... Started the engine . All lights on and flashing like Xmas tree!! Pants I thought ! But soon realised what I had done . Then because of this had the engine light on and a fault code ..... But as luck would have it got my little obd wifi thing through ( same as superstu ) quickly linked it to dash command app and turned it off and wiped the code. What a great little gizmo it is .
Then I went for a drive and scared myself in the damp condition and came to the conclusion I don't need any more than 465bhp !!!
Happy days
  • Like 2
Update .......
All is ok !!!!
Happy days
do somthing that scares you every day :lol:
Update .......
All is ok !!!!
Happy days
I generally do ..... But when you climb trees and have a chainsaw dangling pretty close to yours balls as your day job it takes quite a bit to get my adrenalin going !! Happily the zed did that tonight :)
