Throwing up engine codes P0138, P0158 and P0057
SkylineV35
Been a while since iv posted but just wanted to double check something I have the above codes thrown up. I have decats fitted with 02 extended spacers, usually only the p0138 code throws up and I just erase codes with my reader but yesterday it pulled up the above 3codes. Heater circuit low code is this still due to decats or do I have to replace the bank2 sensor? I read there is a fuse box with a 15amp fuse for 02sensor will check that later.
But main query is are these the usual codes that throw up and can be taken away permanently with uprev? Also if the sensors are faulty im assuiming if i get remap it means I wont need to replace sensors as they arent being used anyway?
Thanks in advance
