Lipsylee Posted September 15, 2015 Share Posted September 15, 2015 Hello does anybody know how much atf gearbox oil the car holds. The pipe came off the rad and poured about 3 litres all over my drive . What oil do I need How much oil And do I empty underneath on the drain plugs and fill up from there or can I fill from the charge pipe ? Thanks lee Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted September 15, 2015 Share Posted September 15, 2015 We can supply the correct Nissan fluid. You need 11 liters for a complete change. Quote Link to comment Share on other sites More sharing options...
Lipsylee Posted September 15, 2015 Author Share Posted September 15, 2015 Ok cheers how much is the oil for 11 litres Is it difficult to do or quite straight forward ? Thanks Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted September 16, 2015 Share Posted September 16, 2015 On 15/09/2015 at 18:39, Lipsylee said: Ok cheers how much is the oil for 11 litres Is it difficult to do or quite straight forward ? Thanks Its expensive stuff it would be £200 for 11 liters for genuine Nissan fluid Quote Link to comment Share on other sites More sharing options...
Lipsylee Posted September 16, 2015 Author Share Posted September 16, 2015 I know it's very expensive , I called my local nissan dealer and they didn't even stock it ! It's coming tomorrow for £185 and he's going give me a little more discount for trade . But wow Just got to make sure I change it correctly haha Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 16, 2015 Share Posted September 16, 2015 Remember that the torque converter holds circa 3 litres, so you will not require the full 11 litres unless you empty the TC. Also make sure that it is J-Matic fluid that they give you. Quote Link to comment Share on other sites More sharing options...
Lipsylee Posted September 16, 2015 Author Share Posted September 16, 2015 Ok nice 1 well I won't be draining that . So 8 litres it is . This is the oil I'm getting in the morning Nissan matic s 999mp mts00sp Is that correct Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 16, 2015 Share Posted September 16, 2015 Yeah, Matic S ATF supersedes Matic J ATF. Matic S is a far superior fluid to Matic J, however I believe that it does require to be changed at a certain mileage where Matic J was a fluid for life. Also I am not sure if they are compatible with each other. Best to have a Google. Quote Link to comment Share on other sites More sharing options...
Lipsylee Posted October 1, 2015 Author Share Posted October 1, 2015 FIXED Quote Link to comment Share on other sites More sharing options...
