coyoteboy Posted September 10, 2015 Share Posted September 10, 2015 Well today I had the fabled clutch weirdness. Lights went green, had to hover at the biting point for 7-8 seconds to wait for a moron dawdling and trying to decide whether to turn across me or not. Eventually I got annoyed and hoofed it around him but as I fed the clutch up it just immediately went into total slip. Clutch hit the floor and stayed there for a second, as I backed off the throttle the clutch came back to life and popped back up. It's now notably lighter (used to have a definite change in spring rate exactly at the biting point, now it's linear). Going to flush through with new fluid and keep an eye out for leaks but it worked fine all the way home. Bugger. Can't trust it now! Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted September 11, 2015 Share Posted September 11, 2015 I'm not expert but I'd say sitting on it full stop isn't a good thing Probly got hot and slipped it a bit Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted September 11, 2015 Share Posted September 11, 2015 Do 370z have the same issue with the 350z HR? My 350 does the same thing, if I try to launch, the peddle just sits on the floor until I it cools down. Only takes a few seconds but is very irritating. Been told to upgrade the clutch line to a SS one but it's a box out job, so won't be happening until the clutch gives up. Quote Link to comment Share on other sites More sharing options...
coyoteboy Posted September 11, 2015 Author Share Posted September 11, 2015 (edited) I'm not expert but I'd say sitting on it full stop isn't a good thing Probly got hot and slipped it a bit Yeah think about that a second, how many times a day do you rest at the biting point ready to dart for a few seconds Next commute you'll surprise yourself. We are talking no load for a few seconds, I'm used to driving a 4wd 350HP manual car Edited September 11, 2015 by coyoteboy Quote Link to comment Share on other sites More sharing options...
Siman350z Posted September 11, 2015 Share Posted September 11, 2015 Clutch slave cylinder, common issue check out U.S. Threads- there are a lot. Check your fluid, if it's black then change it (and look for 'bits' of black stuff- evidence slave is failing) but may just have to end up changing the cylinder. Quote Link to comment Share on other sites More sharing options...
a2orry Posted September 11, 2015 Share Posted September 11, 2015 Don't wait for it failing totally chances are you will end up stuck somewhere with no pedal at all Quote Link to comment Share on other sites More sharing options...
coyoteboy Posted September 11, 2015 Author Share Posted September 11, 2015 Hmm will look at it asap, bit of a pain but 80K old isn't too unreasonable. Hoping it's not due to failing dmf but the slight judder I've had at low revs, low engagement suggests other possible issues. Sent from my HTC One M9 using Tapatalk Quote Link to comment Share on other sites More sharing options...
