Matty_P Posted September 9, 2015 Share Posted September 9, 2015 I've posted a video for you to listen to, try not to cringe :-). Thanks for watching. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted September 9, 2015 Share Posted September 9, 2015 I've posted a video for you to listen to, try not to cringe :-). Thanks for watching. where ? Quote Link to comment Share on other sites More sharing options...
gsexr Posted September 9, 2015 Share Posted September 9, 2015 What video Quote Link to comment Share on other sites More sharing options...
Matty_P Posted September 9, 2015 Author Share Posted September 9, 2015 Sorry, i think i uploaded too much, so im trimming the video. Wont be long now, thankyou. Quote Link to comment Share on other sites More sharing options...
Matty_P Posted September 9, 2015 Author Share Posted September 9, 2015 Here's the video IMG_3006 (2).MOV Quote Link to comment Share on other sites More sharing options...
JetSet Posted September 9, 2015 Share Posted September 9, 2015 Jeez Pete 2 Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted September 9, 2015 Share Posted September 9, 2015 ummm it that a tractor or a diesel? To be honest I would not be running that until a actual mechanic or specialist has look at it Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted September 9, 2015 Share Posted September 9, 2015 (edited) Kinda reminds me of this noise . . . Edited September 9, 2015 by DoogyRev 1 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted September 9, 2015 Share Posted September 9, 2015 Doesn't sound healthy at all mate. As above, better not start up your engine anymore. Quote Link to comment Share on other sites More sharing options...
Juggalo Posted September 10, 2015 Share Posted September 10, 2015 Sounds like a severely loose timing chain tensioner. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted September 10, 2015 Share Posted September 10, 2015 Kinda reminds me of this noise . . . I can't get the video clip to play on my iPad but this made me chuckle OP it sounds like you need to get it to a mechanic as soon as. Quote Link to comment Share on other sites More sharing options...
SHEZZA Posted September 10, 2015 Share Posted September 10, 2015 Kinda reminds me of this noise . . . I can't get the video clip to play on my iPad but this made me chuckle OP it sounds like you need to get it to a mechanic as soon as. +1 Ah those were the day's! 1 Quote Link to comment Share on other sites More sharing options...
TT350 Posted September 10, 2015 Share Posted September 10, 2015 Bearing. Quote Link to comment Share on other sites More sharing options...
philw99 Posted September 10, 2015 Share Posted September 10, 2015 Nothing interfering with the belts? have they been changed recently? Quote Link to comment Share on other sites More sharing options...
Keyser Posted September 10, 2015 Share Posted September 10, 2015 Sounds fairly terminal to me - either bearing or chain I'd go with bearing except the noise seemed to change. Gonna need some work though Good luck Quote Link to comment Share on other sites More sharing options...
Matty_P Posted September 10, 2015 Author Share Posted September 10, 2015 Thanks for the responses. I have changed the two belts a couple of weeks ago. Took it to a garage and he seems to think its bottom end. So I'm guessing a big end or small end bearing? Does anyone know a specialist I can take the car to in the kent area, hopefully near ashford way? Quote Link to comment Share on other sites More sharing options...
HiddenWomble Posted September 10, 2015 Share Posted September 10, 2015 sly at kaizer is near rochester, often recommended on these forums so i've picked him as my main garage. so far he's been very helpful and very reasonable on the price too. he's closer to you than he is to me! he's a nissan master mechanic, and has been in the top 30 master mechanics across the UK twice now over the years. mostly tends to GTRs, 370s and 350s. i'd just be worried about driving your car with those sounds. does anyone know if it's likely to be doing more damage if driven in this state? Quote Link to comment Share on other sites More sharing options...
Matty_P Posted September 10, 2015 Author Share Posted September 10, 2015 Excellent, I'll give him a bell and let you know what it is. If it gets too expensive I'll have to resort to cards to enjoy myself! :-) Quote Link to comment Share on other sites More sharing options...
Keyser Posted September 10, 2015 Share Posted September 10, 2015 That sounds like bearing mate driving it like that you run the risk of it seizing up and that can put a hole in the block (ask Grundy) You may find a second hand engine is a better way forwards though. Quote Link to comment Share on other sites More sharing options...
HiddenWomble Posted September 10, 2015 Share Posted September 10, 2015 he's on the forums too so you can always point him here for a listen. 1 Quote Link to comment Share on other sites More sharing options...
simonlap Posted September 10, 2015 Share Posted September 10, 2015 I would say it's picked up on a bottom end shell bearing. I had a car in last week exactly the same sound. The noise from the white metal bearing shell as it has detaxched gets transferred up the rod and through the piston crown and sounds very loud inside the rocker cover. This particular car was a ford 1.8 Duratec engine and it was big end number one but sounded like exhaust valve number one. Quote Link to comment Share on other sites More sharing options...
Matty_P Posted September 10, 2015 Author Share Posted September 10, 2015 I couldn't actually post the whole video as it's only allowing 1MB, but with slight rev the knocking gets louder and faster, then a bit more and the noise cuts out a bit. Strangely after that the knocking noise has gone now (obviously haven't driven it) so I'm unsure whats going on? Quote Link to comment Share on other sites More sharing options...
TT350 Posted September 10, 2015 Share Posted September 10, 2015 Relax. Just buy a forged bottom end like meeeeee 2 Quote Link to comment Share on other sites More sharing options...
simonlap Posted September 10, 2015 Share Posted September 10, 2015 Matty, same with the 1.8 Duratec. The noise was there at tickover then not again till about 1900 rpm. Strange. It still pulled well and no other obvious issues at the time. Quote Link to comment Share on other sites More sharing options...
veilside z Posted September 11, 2015 Share Posted September 11, 2015 Not good. I feel for you, we have a Z in the family with the same issue. Hope you can get this sorted without too much of a dent in your wallet. Quote Link to comment Share on other sites More sharing options...
