jell36 Posted May 19, 2012 Share Posted May 19, 2012 any solutions to this issue found? I'm finding the same thing with my MY06 Quote Link to comment Share on other sites More sharing options...
narcotix Posted September 4, 2012 Share Posted September 4, 2012 Holy Thread Revival! I kinda forget about the issue with the sticky throttle ... I guess I just got used to it being there ... But over the last few days I've noticed that the gear changes have been a lot smoother and then I noticed that I longer have the sticky throttle problem ... I haven't changed anything other than the fuel pressure regulator last weekend .. I'm not sure if that fixed the problem or not but it's deifnitely not there anymore ... Here's the video I took on the 24th February 2010: and here's a video I took earlier today: The Rev counter is clearly more smoother when the revs are dropping back to idle .. Weird huh? Either way I'm not complaining ... Quote Link to comment Share on other sites More sharing options...
nodge69 Posted March 13, 2015 Share Posted March 13, 2015 Holy Thread Revival! I kinda forget about the issue with the sticky throttle ... I guess I just got used to it being there ... But over the last few days I've noticed that the gear changes have been a lot smoother and then I noticed that I longer have the sticky throttle problem ... I haven't changed anything other than the fuel pressure regulator last weekend .. I'm not sure if that fixed the problem or not but it's deifnitely not there anymore ... Holy thread revival again! Narcotix could ya tell me whether it was the fuel pressure regulator or one of the fuel dampers that you changed? If it was a damper then was it one of the ones on the fuel rails or the one on the fuel feeder pipe on the drivers side? I'm experiencing exactly the same right now. Thanks! Quote Link to comment Share on other sites More sharing options...
bamdc2 Posted March 18, 2015 Share Posted March 18, 2015 Just a shot in the dark mate but have you tried the ECU re set followed by the throttle body re learn then accelerator pedal re learn position? It was the accelerator re learn that fixed my pedal response issues. http://www.350z-uk.com/topic/53148-how-to-ecu-accelerator-pedal-throttle-valve-resets/page__hl__throttle Quote Link to comment Share on other sites More sharing options...
nodge69 Posted March 19, 2015 Share Posted March 19, 2015 Just a shot in the dark mate but have you tried the ECU re set followed by the throttle body re learn then accelerator pedal re learn position? It was the accelerator re learn that fixed my pedal response issues. http://www.350z-uk.c...e__hl__throttle Yep I've been through all of these procedures many times. I actually cleaned my throttle bodies as one attempt to fix it but this led to another problem which I've only just managed to fix, I posted another thread about it today. I might actually just change the two dampers on the fuel rails as they are only £20 each from Nissan. I've found at least a couple of people in the US who have had weird behaviour around 1500 RPM which was totally fixed by changing the dampers. Mine don't make any noise though, maybe there is more than one failure mode on these things. Thanks a lot for the suggestion though! 1 Quote Link to comment Share on other sites More sharing options...
bamdc2 Posted March 19, 2015 Share Posted March 19, 2015 No worries bud, thought you might have done all of those re sets. Well I hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
