narcotix Posted February 1, 2010 Share Posted February 1, 2010 Hmmm ... I've not had any luck with mine either ... Might give the Throttle reset procedure another go ... Is there any sort of indication that the reset has actually worked? Quote Link to comment Share on other sites More sharing options...
haydar Posted February 3, 2010 Share Posted February 3, 2010 Hi all Wanted to know if any progress had been made on this. I also have an 06 350z and it has the same 'sticky' throttle feeling. The revs don't drop as far or as fast as they should! Quote Link to comment Share on other sites More sharing options...
Cragus Posted February 3, 2010 Share Posted February 3, 2010 This happened to me after not driving my car in the summer for a couple of weeks when was on holiday. Was really annoying as the drive became quite a jerky one. I put in a can of redex (but stronger) type liquid in my tank when running a quarter tank of petrol and did a ferocious bit of motorway driving which seems to iron this little issue up for me. Don't know how or why but it worked! Never had a problem since. Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 3, 2010 Share Posted February 3, 2010 Sorry ... I've not had any breakthroughs with this issue .. I haven't had a chance to try much though so far ... will see if I get some time over the weekend ... Quote Link to comment Share on other sites More sharing options...
srobrien Posted February 3, 2010 Share Posted February 3, 2010 Remove the TB and give the butterfly valve a good clean with some mechanical cleaner and a clean paint brush, then do a reset. R Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted February 4, 2010 Share Posted February 4, 2010 Mine has developed this problem,when I dip the clutch going slow the revs pick up then and hold for a couple of seconds then drop. Looks like the stealers are going to be paid a visit. Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 5, 2010 Share Posted February 5, 2010 Mine has developed this problem,when I dip the clutch going slow the revs pick up then and hold for a couple of seconds then drop. Looks like the stealers are going to be paid a visit. I have that problem also ... I was under the impression that the two were related ... It's like I'm reving the engine slightly everytime I dip the clutch ... Quote Link to comment Share on other sites More sharing options...
Cragus Posted February 7, 2010 Share Posted February 7, 2010 Mine has developed this problem,when I dip the clutch going slow the revs pick up then and hold for a couple of seconds then drop. Looks like the stealers are going to be paid a visit. I have that problem also ... I was under the impression that the two were related ... It's like I'm reving the engine slightly everytime I dip the clutch ... A 350z with sychro rev!! You manage to get this sorted yet? Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted February 10, 2010 Share Posted February 10, 2010 My car is booked in for fri with the stealers,so should have some info on the problem then. Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 10, 2010 Share Posted February 10, 2010 My car is booked in for fri with the stealers,so should have some info on the problem then. Nice one! Hope it's not an expensive fix for your sake and mine ... LoL Keep us informed ... Quote Link to comment Share on other sites More sharing options...
Cragus Posted February 10, 2010 Share Posted February 10, 2010 This happened to me after not driving my car in the summer for a couple of weeks when was on holiday. Was really annoying as the drive became quite a jerky one. I put in a can of redex (but stronger) type liquid in my tank when running a quarter tank of petrol and did a ferocious bit of motorway driving which seems to iron this little issue up for me. Don't know how or why but it worked! Never had a problem since. Have you tried this alongside with removing the TB and cleaning the butterfly valve? Could be an easy fix? Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 10, 2010 Share Posted February 10, 2010 I wouldn't know where to start with cleaning the butterfly valve on the Throttle Body ... Is there any guides on the forum anywhere that might help? Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted February 12, 2010 Share Posted February 12, 2010 Right i have been to the stealers this afternoon and have advised me that it looks like carbon build up is the cause.They have given me a bottle of fuel system cleaner to put in my tank and run for about a week to see if this clears the problem.Failing that it needs to go back in the have the throttle body stipped and cleaned and other parts on the intake side. to Cragus who mentioned this route earlier in the thread hope it works. Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 12, 2010 Share Posted February 12, 2010 That's good news ... Doesn't sound like an expensive fix then ... What Fuel System cleaner did they give you ... Is it a Nissan branded one? Can anyone recommend a good cleaner ... I've used RedEx in the past but there must be something better out there ... Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted February 12, 2010 Share Posted February 12, 2010 Havoline Performance Plus. Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 12, 2010 Share Posted February 12, 2010 Thanks for that ... I'm gonna try and get some tomorrow ... Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted February 12, 2010 Share Posted February 12, 2010 Think I am going to be adding this every 12 month from now on. Quote Link to comment Share on other sites More sharing options...
narcotix Posted February 12, 2010 Share Posted February 12, 2010 Let me know how you get one after using the Fuel System Cleaner ... I'm going to call my local stealer tomorrow to see if they have any in stock ... failing that I've looked on the internet for stockists and the closet one is 11 miles away ... It would be great if it resolves the issue but i suppose it's worth doing anyway .. Quote Link to comment Share on other sites More sharing options...
scottsoulby Posted February 12, 2010 Share Posted February 12, 2010 same problem with mine, ill go buy some of that stuff tommorrow to try Quote Link to comment Share on other sites More sharing options...
Cragus Posted February 12, 2010 Share Posted February 12, 2010 Right i have been to the stealers this afternoon and have advised me that it looks like carbon build up is the cause.They have given me a bottle of fuel system cleaner to put in my tank and run for about a week to see if this clears the problem.Failing that it needs to go back in the have the throttle body stipped and cleaned and other parts on the intake side. to Cragus who mentioned this route earlier in the thread hope it works. I don't like to boast! Get something a bit stronger than redex! Put it in when your running low and horse it...! Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted February 13, 2010 Share Posted February 13, 2010 Yeah they told me to run the tank low and give it a blast down the motorway when its had warmed up. Quote Link to comment Share on other sites More sharing options...
fakeindian Posted February 13, 2010 Share Posted February 13, 2010 Yeah they told me to run the tank low and give it a blast down the motorway when its had warmed up. dude how big is the bottle they gave you?? i.e 1LTR?? Quote Link to comment Share on other sites More sharing options...
alessandro Posted February 13, 2010 Share Posted February 13, 2010 Havoline Performance Plus. Is this something that needs doing every now and again/ Never use any of those products before Quote Link to comment Share on other sites More sharing options...
fakeindian Posted February 13, 2010 Share Posted February 13, 2010 Havoline Performance Plus. Is this something that needs doing every now and again/ Never use any of those products before apparently every 6 months Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted February 13, 2010 Share Posted February 13, 2010 Who told you every 6 months Neil? Bottle is 350 ml. Quote Link to comment Share on other sites More sharing options...
