Nigelp Posted December 11, 2007 Share Posted December 11, 2007 I`ve noticed this happens all the time, if I`m accelerating, press clutch pedal to change gear and lift off accelerator, change gear and as i`m releasing the clutch, the engine revs havent fallen. Its just as if the throttle cable is sticking slightly. Its more noticeable when accelerating through the gears hard, my passenger commented the other day and asked why I wasnt lifting off when changing gear !. I told them to watch my feet and they saw I was lifting my foot clear from the accelerator but the revs didnt drop Is this normal or something on my car? (06 model) tried searching but had no hits for `sticking throttle`... Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted December 11, 2007 Share Posted December 11, 2007 Mine also appears to do this but I have learn't to live with it. The throttle on the Zed is fly-by-wire so can't really stick. What revs is it idling at when warm? If it's higher than about 750 - 800 rpm with the climate control off, then it needs adjusting. Quote Link to comment Share on other sites More sharing options...
Nigelp Posted December 11, 2007 Author Share Posted December 11, 2007 its fine at idle. Of course its Fly-by-wire. DOH !!!!! I forgot that...... well, whatever it is, the symptoms are like a sticking throttle Quote Link to comment Share on other sites More sharing options...
M13KYF Posted December 11, 2007 Share Posted December 11, 2007 may be worth doing a ECU reset. http://www.350z-uk.com/forum/viewtopic.php?t=89 Similarly it could be something to do with the MAF sensor.. I don't suffer with the same problem Quote Link to comment Share on other sites More sharing options...
H5 Posted December 20, 2007 Share Posted December 20, 2007 Or you're just not changing gear properly!! Quote Link to comment Share on other sites More sharing options...
Stez Posted December 20, 2007 Share Posted December 20, 2007 I had some problems recently after having having a new exhaust fitted. The problem was 'hunting' as if the throttle cable was stuck!. Even after trying an ECU reset the car when to 'limp' mode. Anyway the resultant problem was diagnosed as a faulty throttle pedal sensor. Warranty job in the end. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted December 20, 2007 Share Posted December 20, 2007 Glad you got sorted - the reset you should try is not the ECU reset (although this never hurts) but the throttle position reset (Accelerator Pedal Release Position Learning) http://www.technosquareinc.com/350reset.htm Quote Link to comment Share on other sites More sharing options...
M13KYF Posted December 20, 2007 Share Posted December 20, 2007 Glad you got sorted - the reset you should try is not the ECU reset (although this never hurts) but the throttle position reset (Accelerator Pedal Release Position Learning)http://www.technosquareinc.com/350reset.htm nice one dorian, added it to the guides Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted December 20, 2007 Share Posted December 20, 2007 Glad you got sorted - the reset you should try is not the ECU reset (although this never hurts) but the throttle position reset (Accelerator Pedal Release Position Learning)http://www.technosquareinc.com/350reset.htm nice one dorian, added it to the guides np - not a panacea, but just a starting point if you have issues. [[whilst you're looking at Guides section Mike, can you change the ECU Reset Guide thread's link to technosquare.com to technosquareinc.com (at the bottom of the post) - technosquare.com is some other outfit entirely]] Quote Link to comment Share on other sites More sharing options...
M13KYF Posted December 20, 2007 Share Posted December 20, 2007 done Quote Link to comment Share on other sites More sharing options...
bigphil Posted December 20, 2007 Share Posted December 20, 2007 The butterfly on the throttle body also gets very gunked up with residue and can cause a sticking throttle. Needs to be reset after cleaning. Quote Link to comment Share on other sites More sharing options...
Nigelp Posted May 9, 2008 Author Share Posted May 9, 2008 Right, I`m trying to get to the bottom of this. Been to main dealer and they say its `normal` so could someone do me a favour and try the following please? I find the motorway best, but in 6th, at 70, put your foot to the floor for say 5 seconds, then push the clutch and at the same time come off the accelerator. Mine holds the revs for just under a second before dropping. I`d expect the revs to fall immediately when I dip the clutch and release the throttle. Could someone post their findings so I know if they are all like that or just mine. It works in and gear, when you hold full throttle for a few seconds depress the clutch/accelerator, I just find it safer and repeatable when I do it on the motorway/ dual carriageway. Cheers, Nige. Quote Link to comment Share on other sites More sharing options...
Nigelp Posted May 12, 2008 Author Share Posted May 12, 2008 Anyone, please? :bye: Quote Link to comment Share on other sites More sharing options...
Nigelp Posted December 11, 2008 Author Share Posted December 11, 2008 Fletch (Mechanic at ESR) sat in the car today and said he didn`t think it was normal either. I`m going to go to the main dealer AGAIN to try and get it sorted once and for all. It would have been nice to be able to go and say i`ve had other 350Z owners test theirs and not suffer the same symptoms..... Quote Link to comment Share on other sites More sharing options...
Darren-B Posted December 11, 2008 Share Posted December 11, 2008 it could be a vacuum hose, split, worn or unplugged, check all hoses around the plenum when engine running, listen for hissin noises, get someone 2rev the car 2. I had a vacuum problem in my audi, the pipe had been rubbing and slowly made a hole in it. Quote Link to comment Share on other sites More sharing options...
cgomez1978 Posted December 11, 2008 Share Posted December 11, 2008 mine does the same but it's more noticable when i just take my foot off the accelerator it takes it a second or so before the actual rev's start to drop. it makes it feel like the car is jerking Quote Link to comment Share on other sites More sharing options...
Fletch Posted December 12, 2008 Share Posted December 12, 2008 Ive never noticed it before because we dont really drive costomers cars hard so driving normaly it isnt a problem, however at full revs around a corner changing quickly would cause the rear to step out, surely this cant be right. fletch Quote Link to comment Share on other sites More sharing options...
cgomez1978 Posted December 12, 2008 Share Posted December 12, 2008 fletch when i bring mine up next week could you have a look at it, it feel's like the accelerator is sticking i know it cant but it just holds the rev's for a second before dropping its really annoying Quote Link to comment Share on other sites More sharing options...
narcotix Posted January 27, 2010 Share Posted January 27, 2010 Bump .. I've been experiencing the same issue on my Zed ... Has anyone made any progress with identifying or resolving this problem? Quote Link to comment Share on other sites More sharing options...
stanski Posted January 27, 2010 Share Posted January 27, 2010 Hope you get to the bottom of this one folks (fortunately never had an issue with mine) but before I got mine I did read about a woman that had been killed as her accelerator jammed on and she crashed at a junction a few years ago? Probably a very rare event but worth just checking just the same Quote Link to comment Share on other sites More sharing options...
narcotix Posted January 27, 2010 Share Posted January 27, 2010 Hmmm ... all of a sudden the urgency of this problem has increased ... Quote Link to comment Share on other sites More sharing options...
stanski Posted January 27, 2010 Share Posted January 27, 2010 Hmmm ... all of a sudden the urgency of this problem has increased ... Hey I did'nt mean to panic anyone - how many have been sold here since 2003 and how many have crashed because of this potential issue - just 1 ? Of course how many more have ended up in ditches is another thing but we all know what that is!! Quote Link to comment Share on other sites More sharing options...
narcotix Posted January 27, 2010 Share Posted January 27, 2010 Hahaha ... Don't worry it's not panicked me at all ... I've had this issue since I bought the Zed and have learnt live with it ... I just wanted to know if anyone had any success with resolving it ... Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 27, 2010 Share Posted January 27, 2010 Bump .. I've been experiencing the same issue on my Zed ... Has anyone made any progress with identifying or resolving this problem? have you tried any of the suggestions on the previous page? Quote Link to comment Share on other sites More sharing options...
Nigelp Posted February 1, 2010 Author Share Posted February 1, 2010 I haven`t fixed mine. Learned to live with it, not ideal but hey ho. Quote Link to comment Share on other sites More sharing options...
