Motordyne XYZ/ART, HSD coilovers ***bank holiday special on ART!***
Arran
Motordyne XYZ y pipe with resonator, if you know about motordyne you'll know this is easily the best y pipe available for a Z and don't come up for sale often because of the price and availability. A lot of research and development went into this making it the right length and shape, also for the swappable mid section in which you can have a straight pipe, resonator or sports cat (so you can run decats with still pass mot), I opted for the resonator as mot isn't an issue, tried the cobra y pipe before this it was ok but this is leagues ahead in terms of quality and sound. One flexipipe has a very slight scuff from a speed bump but motordyne use a double thickness flexi to ensure no common failures like the cheaper brands. Was on the car for around 7k miles. £350 collected
Motordyne ART decat pipes, again these are the best decats available for the Z and not often up for sale. I tried some resonated decats from Horsham developments before and it was unbearably loud, swapped over to these and I couldn't believe the difference in sound quality (no rasp compared to other decats without a helmholtz resonator) and volume, easily liveable day to day. Were on the car for around 7k miles, brilliant quality and still in perfect condition. £325 collected
Eibach 20mm front and 25mm rear spacers, went with Eibach because of the quality of the brand and research and development into their products, not worth cheaping out on a part so vital imo. We're on the car for about 9k. Will come in the original boxes to. £165 collected
HSD dual tech coilovers, I opted for these over the monopro's because much like the E36/46 BMW the rear shock towers aren't designed to take the full load of a true coilover without some strengthening work. I also wanted a more comfortable coilover for road use and the occasional track day and ring trip. These have proved faultless and a great coilover, set them up for the stiffness you want on the road and then when at the track within 5 minutes set all four to the stiffness you desire, all adjusters are at the top of the shock making it effortless. The bodies were coated with collinite 476s wax and the threads/adjusters with castrol chain lube to keep everything clean and moving freely before installation. Been on the car about 7k miles and as you can see are still in fantastic condition, very slight surface rust on the rear springs none on the front. Will come in the original box. £400 collected, I will also throw in 2 new cans of wurth 2040 lubricant for when you put them on.
I'm happy to deliver any of the above within a 10-15 miles radius from Epsom, Surrey
Cheers
Arran
Edited by Arran
PM replied
Will also have genuine facelift led rear lights, mocal oil cooler and temperature gauge setup, motordyne plenum spacer and a fair few other bits for sale in the next week or so
Here's a video of my exhaust setup, dc sports exhaust manifolds, XYZ with resonator y pipe, art decats and cobra resonated mid and rear (car has a ultra lightweight flywheel in it to)
Edited by Arran
Yeah ran one for the temp gauge and one for the lines bro, the whole setup is for sale still looks pretty much new tbh didn't cover a lot of miles and was a godsend on track and spirited road driving, didn't see over 106c at the ring! Selling the car mate yeah
Coilovers are sold bud, thank you though
Pictures to come but got more coming up this week
Black genuine nismo gearknob
Genuine carbon rest strut trim
Brand new gold DE engine bolt set
Number plate reverse camera
Horsham earthing kit
Brand new oil catch can
JDM only centre console twin cup holder
Facelift airbox, hks panel filter and black Samco intake pipe
hi andy
the oil cooler is still available, it does have a thermostat that opens at 85c, I wouldnt run one without on the road. the cooler is a mocal 13row, aeroquip blue socketless hose,aeroquip blue and red fitting, r spec temp sensor sandwhich plate, mocal thermostatic plate, pro sport led temp gauge with custom pod a pillar
its a proper kit no cheap parts on a vital component, only thing you'd need is the 2 mocal mounts from merlin motorsport 7 pounds
its up for 400 which is alot cheaper than what it cost me not very long ago, i have pictures if you want to pm me
cheers
