slipstream Posted August 19, 2015 Share Posted August 19, 2015 Hi, just got some side steps from a member which are new so not been drilled for fitting, so my question is has anyone got a template to do this ? Thanks, Stuart. Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted August 19, 2015 Share Posted August 19, 2015 (edited) Hi, give Chris at Tarmac a ring and he will be able to tell you the spacing it's easy enough. Edited August 19, 2015 by Mopedmark 1 Quote Link to comment Share on other sites More sharing options...
slipstream Posted August 19, 2015 Author Share Posted August 19, 2015 Cheers mopedmark. Quote Link to comment Share on other sites More sharing options...
buster Posted August 19, 2015 Share Posted August 19, 2015 Fitting Guide Tools Required: 7mm high speed drill bit and drill Tape measure Marker pen 10mm socket and ratchet Scrap piece of wood Masking tape (not essential) Car Jack Axle stands An extra pair of hands is always helpful but not essential If you have pre-existing side steps you must remove these first, it may be possible to use them as a template but this is not essential (see NB on page 2) Which side is which? (see Figure 1) figure 1: this shows the DRIVERS side (offside) step. Notice the square edge to the left and the lower platform to the right. Starting with the driver's side (offside): Using your marker pen and tape measure mark a line 7-8 mm from the top edge all the way along the length of the step (see figures 2 and 3) figure 2 figure 3 Starting from the raised edge on the left hand side using the marker pen, mark at the following points: (see figure 4) 5.5cm 27.7cm 51.2cm 74.7cm 98.2cm 121.6cm 167cm figure 4 N.B once the holes are marked and BEFORE drilling, offer the step up to the car to ensure that the marks line up with your existing bolt holes (some cars may have had modifications). If the holes do not line up it is recommended that you remove the OEM side skirt and place it on top of your new side step as a template. Place the piece of scrap wood under the place where you are going to drill the hole, this is essential as it supports the step and prevents cracking. (see figure 5) figure 5 Using the high speed drill bit, carefully and confidently drill the hole. Do not push the drill through, let the drill eat its way through. If you are concerned you can apply masking tape over the spot that you want to drill as this can also help prevent cracking, chipping and tear out. Continue this process until all 7 holes are drilled. Now offer the step up to the car, starting in the middle insert the screws, do not tighten until all 7 screws are in place (see figure 6) figure 6 NB. Do not over tighten the bolts as this may damage the side step Passengers Side (Near side) Repeat the process as above but start from the right hand side when measuring. Stand back and admire your new look 1 Quote Link to comment Share on other sites More sharing options...
slipstream Posted August 20, 2015 Author Share Posted August 20, 2015 Thanks buster. Quote Link to comment Share on other sites More sharing options...
buster Posted August 20, 2015 Share Posted August 20, 2015 hope it helps m8......was written by by Mrs Keyser and myself for tarmacsportz....if you pm me your email addy i ll send the pdf to you with the pics Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted August 20, 2015 Share Posted August 20, 2015 A good tip for drilling fiberglass is run the drill in reverse briefly, it gentley scores the hole and stops splintering, cracking and gives the drill bit a good guide. 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted August 20, 2015 Share Posted August 20, 2015 Excellent help and advice always to hand on here. 1 Quote Link to comment Share on other sites More sharing options...
KyleR Posted August 20, 2015 Share Posted August 20, 2015 A good tip for drilling fiberglass is run the drill in reverse briefly, it gentley scores the hole and stops splintering, cracking and gives the drill bit a good guide. Great tip Quote Link to comment Share on other sites More sharing options...
