Twi6453 Posted August 18, 2015 Share Posted August 18, 2015 Hi guys Is there a part you can add to the door to stop the windscreen wash from coming in while the window is down? Quote Link to comment Share on other sites More sharing options...
Stutopia Posted August 18, 2015 Share Posted August 18, 2015 Don't about the roadster but in my coupe it's windscreen wash or window down, never both! 1 Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted August 18, 2015 Share Posted August 18, 2015 Yes. It's commonly referred to as "a window". The worst part is, I'm not even sorry. 1 Quote Link to comment Share on other sites More sharing options...
Twi6453 Posted August 18, 2015 Author Share Posted August 18, 2015 haha no @*!# Sherlock so it is a common thing then Quote Link to comment Share on other sites More sharing options...
HaydnH Posted August 18, 2015 Share Posted August 18, 2015 haha no @*!# Sherlock so it is a common thing then Yep... at least my door card is the cleanest part of my car. 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted August 19, 2015 Share Posted August 19, 2015 Stop off in a layby when you want to squirt the washer pump and activate the wipers, then the wash will be under control, while your in there you could wash the screen by hand. Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted August 19, 2015 Share Posted August 19, 2015 I try to make sure I'm stationary when using the washers unless the visibility is that bad I need it. It's usually bad enough when I use them the windows uo anyway. Quote Link to comment Share on other sites More sharing options...
