andyk3090 Posted August 18, 2015 Share Posted August 18, 2015 The 07 we picked up has the low oil pressure on the HR engine. (I know, how did I miss it on the test drive...). As everything else is spot on and it runs fine (and based on the low price paid) we have decided to keep it and do the oil gallery gaskets. Hopefully this is all it is, based on the well known issues with this engine. Parts are ordered and will probably get it done in the next few weeks. Any tips or hints in doing this job will be gratefully received. I have done a few timing belts/chain replacements in the past and it seams manageable looking at the manual and other posts. Thanks for any advice given. Regards Andy Quote Link to comment Share on other sites More sharing options...
Renegade Posted August 18, 2015 Share Posted August 18, 2015 If it has not been done already. I think I would be tempted to change oil and filter and make sure there is enough oil in it. My 350 used to use very little between services but a couple of egg cups full were enough to drop the gauge pressure a bit. Quote Link to comment Share on other sites More sharing options...
N4eay Posted August 18, 2015 Share Posted August 18, 2015 What do you mean by low, is the engine up to temperature? What revs is it doing? Just interested as I have an HR. Thanks Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 18, 2015 Author Share Posted August 18, 2015 What do you mean by low, is the engine up to temperature? What revs is it doing? Just interested as I have an HR. Thanks With engine up to temperature it is just sitting about 5psi when ticking over. At 2000 rpm it is about 15 psi and at higher revs around 25 - 30psi. I recon it is about 50% of what it should be. Regards Andy Quote Link to comment Share on other sites More sharing options...
GriffGTV Posted August 18, 2015 Share Posted August 18, 2015 is it only the HR which has oil press gauge as stD? Is there an upgrade for this inadequate std part to prevent this alarming event re-ocurring Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 18, 2015 Author Share Posted August 18, 2015 is it only the HR which has oil press gauge as stD? Is there an upgrade for this inadequate std part to prevent this alarming event re-ocurring The replacement gasket for the oil galleries (which are the ones that blow) are now reinforced rather than just paper gaskets. Reading on the American websites for these HR engines, it looks like most peoples will go this way with mileage/age. Depends how stressed I get doing it, I may take some photos of the strip down and repair as I go along. Not sure if it is just the HR that has the oil pressure guage, I thought they all had one. Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 18, 2015 Share Posted August 18, 2015 All UK Zeds have an oil pressure gauge and (from memory) should read min 14.7 at tickover and 60 psi at 60 mph in sixth gear when the engine is warm ... I traded my Zed at 7 years purely because the oil pressure had dropped to about the same readings as yours ... oh, and it's worth repeating that the guy who designed the DE dipstick was a dipstick Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 18, 2015 Share Posted August 18, 2015 Very unusual to hear a HR engine with oil pressure issues. What mileage has the car done? No oil leaks I presume? What makes you think you need to change the timing chain - have you got a pic of the engine bay? Quote Link to comment Share on other sites More sharing options...
Roscoe Posted August 18, 2015 Share Posted August 18, 2015 Will be the gaskets ðŸ‘🻠Quote Link to comment Share on other sites More sharing options...
Roscoe Posted August 18, 2015 Share Posted August 18, 2015 http://www.350z-uk.com/index.php?/topic/98208-HR-Low-oil-pressure%3F-The-answer Quote Link to comment Share on other sites More sharing options...
ZEUS Posted August 18, 2015 Share Posted August 18, 2015 Yep gaskets , it's a known fault . Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 19, 2015 Author Share Posted August 19, 2015 Very unusual to hear a HR engine with oil pressure issues. What mileage has the car done? No oil leaks I presume? What makes you think you need to change the timing chain - have you got a pic of the engine bay? Colin 96K on the clock, no oil leaks as the oil leaks internally back in to the sump. No pictures as yet, I hope to take some when I get round to doing it, No need to change the timing chain although I might do it as it is off. Only reason is the plates over the gaskets are behind the timing chain, hence it has to come off. Quote Link to comment Share on other sites More sharing options...
AMT Posted August 20, 2015 Share Posted August 20, 2015 Don't usually hear HR's with oil problems. Try the 60 at 60 thing Quote Link to comment Share on other sites More sharing options...
steve916 Posted August 20, 2015 Share Posted August 20, 2015 Have a look through my build thread ( link in signature below). I had this problem and it's all sorted now í ½í± Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 21, 2015 Author Share Posted August 21, 2015 Have a look through my build thread ( link in signature below). I had this problem and it's all sorted now ������ The pictures are great thanks. It looks a very clear view from the front. Was the area in front of the engine just clear because the radiator was removed or had they removed other items such as the crash panel and front panel etc? Just wondering how much I can get away with to minimise the strip down for the timing chain removal. Many thanks Andy Quote Link to comment Share on other sites More sharing options...
steve916 Posted August 21, 2015 Share Posted August 21, 2015 Have a look through my build thread ( link in signature below). I had this problem and it's all sorted now ������ The pictures are great thanks. It looks a very clear view from the front. Was the area in front of the engine just clear because the radiator was removed or had they removed other items such as the crash panel and front panel etc? Just wondering how much I can get away with to minimise the strip down for the timing chain removal. Many thanks Andy Mitz and his team at Cougar Store did the work, but I'm pretty sure they removed crash panel and everything to get in there. Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 21, 2015 Author Share Posted August 21, 2015 Have a look through my build thread ( link in signature below). I had this problem and it's all sorted now ������ The pictures are great thanks. It looks a very clear view from the front. Was the area in front of the engine just clear because the radiator was removed or had they removed other items such as the crash panel and front panel etc? Just wondering how much I can get away with to minimise the strip down for the timing chain removal. Many thanks Andy Mitz and his team at Cougar Store did the work, but I'm pretty sure they removed crash panel and everything to get in there. OK thanks, I guess I will just keep removing bits until I get in... Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 21, 2015 Share Posted August 21, 2015 I find it best to remove bumper, front panel, rads and fans. A few extra hours work, however much easier when re-timing the engine. 1 Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 21, 2015 Author Share Posted August 21, 2015 I find it best to remove bumper, front panel, rads and fans. A few extra hours work, however much easier when re-timing the engine. Many thanks, sounds the way to go. Andy Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted August 21, 2015 Share Posted August 21, 2015 Just make sure the car does not go anywhere near Maltings Off Road, otherwise it will be off road for longer than you'd hoped Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted August 22, 2015 Share Posted August 22, 2015 I'm gonna guess you got this car as a "bargain" Quote Link to comment Share on other sites More sharing options...
HiddenWomble Posted August 22, 2015 Share Posted August 22, 2015 After reading about the oil gallery gasket fault I'm planning to put it on the list of bits to save up for this year to get her running her best. Currently my oil pressures are verging on running high, but after having a chat with sly the gasket problem could be present even if the pressures are fine. He said there is a chance the gasket has cracked further down the line from where the sensor is, but at that point the most important parts will be getting plenty of oil so until you see a pressure drop it's unlikely to do any damage. This gives me a bit of time to save up but I'll be keeping an eye on those numbers in case I need to stretch to fit it in earlier. Best of luck to you Andy, hope she's off and on the road quick enough so you don't miss her too much Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 22, 2015 Author Share Posted August 22, 2015 Just make sure the car does not go anywhere near Maltings Off Road, otherwise it will be off road for longer than you'd hoped I only went there once with my sons Vectra to get a cam belt changed. They over tightened it and it whined on its return. We took it back and they said it was normal and would bed in. HAHAHA. He went to work at RAF Lossiemouth in the north of Scotland and back and it was exactly the same. They were reluctant to take it back in but we wouldn't back down and they put it right. Only time I have ever asked them to do anything. Quote Link to comment Share on other sites More sharing options...
andyk3090 Posted August 22, 2015 Author Share Posted August 22, 2015 (edited) I'm gonna guess you got this car as a "bargain" Yeah, only paid £6k so have some cash to play with. We put aside £1k for any work needing doing, it is coming in at around £400.00 for all parts and that is also doing the timing chain and water pump as a precaution. It will be good experience for my son as well as I stand over him barking instructions while drinking coffee... Edited August 22, 2015 by andyk3090 1 Quote Link to comment Share on other sites More sharing options...
Bodyboarder81 Posted August 22, 2015 Share Posted August 22, 2015 What sort of miles are people having these issues at ? Quote Link to comment Share on other sites More sharing options...
