sianny Posted August 17, 2015 Share Posted August 17, 2015 Had a service last week and been waiting patiently for a cost through to fix a job they said needed doing urgently. I've just chased them 9 days later and been quoted nearly £800 can someone tell me if I'm being duped: The front passenger side arm thing was no longer in / around / on the bushes? Someone called it a wishbone on the day it had a service and on the video they showed me the mechanic said that this certain thing should go around the white thing on another part, but it wasn't attached anymore and that was very bad... anyways it's now been called a Rod Complete Compression Front Suspension... because of this the inner tyre on that corner is totally worn so as soon as the part is back on the bushes I'll get a new tyre. These Rod Complete Compression Front Suspension are £256.18 + VAT and £180 for an hours work (I'm in the wrong business). Also "...if I'm doing one I may as well do both" I laughed Can anyone make sense of what the garage told me and is there a better part than the Nissan part they've quoted? Also anyone know where I should go for a good service in North Wales? I'm trying to get them to send me the video of the mechanic under my car, I'll add the link if I get it. I totally understand that everything I've written above is exactly why girls like me should have boyfriends that "do cars" Quote Link to comment Share on other sites More sharing options...
Pritchard Posted August 17, 2015 Share Posted August 17, 2015 compression arms arnt cheap. mine have also recently turned to chocolate. subscribing to thread. Quote Link to comment Share on other sites More sharing options...
gareth29 Posted August 17, 2015 Share Posted August 17, 2015 It probably just need replacement compression arm bushes - its really common and it wont cost 800 quid (think they are about £35 each?). Better to find a recommended specialist - someone will recommend one Quote Link to comment Share on other sites More sharing options...
Mack Posted August 17, 2015 Share Posted August 17, 2015 The compression rod is basically a metal rod, on one end there is a rubber bush and the other there is a ball joint. Its common for the bushes to fail and they can be replaced for around £80 + labour. The ball joint can also fail however in this case the whole arm must be changed. The best course of action is to get it into a garage that really know these cars, I am no where near Whales so I can't offer any recommendations however I'm sure someone will be able to point you in the right direction. Any needed parts can be sourced at reasonable prices from traders on this forum. Quote Link to comment Share on other sites More sharing options...
Renegade Posted August 17, 2015 Share Posted August 17, 2015 These were recommended on here http://www.niss-tec.co.uk/ Horesham Developments is a little drive away. http://h-dev.co.uk/index2.php?page=home Quote Link to comment Share on other sites More sharing options...
sianny Posted August 17, 2015 Author Share Posted August 17, 2015 eee you're all so helpful, I'll have a look through what you've suggested Quote Link to comment Share on other sites More sharing options...
JetSet Posted August 17, 2015 Share Posted August 17, 2015 These Rod Complete Compression Front Suspension are £256.18 + VAT and £180 for an hours work (I'm in the wrong business). Also "...if I'm doing one I may as well do both" I laughed Can anyone make sense of what the garage told me and is there a better part than the Nissan part they've quoted? Also anyone know where I should go for a good service in North Wales? ZManalex sells these genuine Nissan parts for £137.50 including VAT and postage. Serviceyourcar in Buckley fitted them for around a £100 plus VAT....I had to have both mine and the wife's Zed done. Pete Quote Link to comment Share on other sites More sharing options...
GreenLandy Posted August 17, 2015 Share Posted August 17, 2015 Unless, as mentioned, the balljoint is knackered, or the arm is seriously worn, then complete replacement is totally unnecessary. 2 genuine bushes are ~£75. A garage near me has apparently perfected the job to 40 mins so I'd expect it all in for around £120. 40 mins is certainly better than the near 40 hours it took me last weekend due to horrendous amounts of corrosion holding the damn thing on. Quote Link to comment Share on other sites More sharing options...
Piranha Posted August 19, 2015 Share Posted August 19, 2015 If it's the front lower control arms that go to the hub and the bottom of the strut, I'm getting the bushes replaced in these tomorrow with whiteline bushes, I'll let u know if any problems fitting. Quote Link to comment Share on other sites More sharing options...
sianny Posted August 21, 2015 Author Share Posted August 21, 2015 Update: Bought the parts from ZManalex will fit them on the driveway as soon as I get them There might be another thread next week Quote Link to comment Share on other sites More sharing options...
Mack Posted August 21, 2015 Share Posted August 21, 2015 Good stuff! Beware getting the arms off can be a nightmare, I gave up and took mine to Horsham Developments in the end. Probably a good idea to get a wheel alignment after. Mack Quote Link to comment Share on other sites More sharing options...
sianny Posted August 21, 2015 Author Share Posted August 21, 2015 I've been told there are some tricks to getting them off. I'm really hoping Trick 1 isn't "Take it to a garage" Quote Link to comment Share on other sites More sharing options...
Mack Posted August 21, 2015 Share Posted August 21, 2015 The end thats attached to the car (bush end) tends to be the one thats stuck. I tried everything on mine and in the end took it to Horsham. After telling me they "had to get medieval on it" they welded a bar to the bush and hammered it off. You might get lucky and it will just pop off however if you take it to a garage it should only be a couple of hours of labour. Either way it should cost a lot, lot less than £800. Don't forget to do both sides, if one side has gone the other isn't far behind. Zmanalex almost certainly has given you the parts for both sides. Quote Link to comment Share on other sites More sharing options...
sianny Posted August 21, 2015 Author Share Posted August 21, 2015 Yep definitely bought the parts for both sides, he also recommended some seating cones, bought them too. Quote Link to comment Share on other sites More sharing options...
gareth29 Posted August 21, 2015 Share Posted August 21, 2015 Yep definitely bought the parts for both sides, he also recommended some seating cones, bought them too. From the way you're talking I would definitely get someone to do them for you. I did mine and it was not straight forward - and I got a local place to press the old bushes out and the new bushes in (cost a tenner) . Just saying Quote Link to comment Share on other sites More sharing options...
sianny Posted September 29, 2015 Author Share Posted September 29, 2015 Yep definitely bought the parts for both sides, he also recommended some seating cones, bought them too. From the way you're talking I would definitely get someone to do them for you. I did mine and it was not straight forward - and I got a local place to press the old bushes out and the new bushes in (cost a tenner) . Just saying Me, my boyfriend, and 2 friends did it on the driveway, so to speak. We didn't need a garage though we did make 1 call to zmanalex Quote Link to comment Share on other sites More sharing options...
gareth29 Posted September 29, 2015 Share Posted September 29, 2015 Result 1 Quote Link to comment Share on other sites More sharing options...
