Blue Smoke, DE Engine
Massingham
So, I've done a compression test today. Unfortunately I don't have access to leak down test equipment
All 6 cylinders are within the 185-190 PSI range, no major variation
Cylinders 2 and 4 (I believe... Closest two cylinders to the front of the car on the right head) both had oil covered spark plugs, 2 being somewhat worse than 4.
Not sure where to go from here other than to go ahead and change the stem seals and take it from there.
If you had a major crack, then I think that you would know about it. :lol:
A wet compression test is simply a way of getting an indication if you have oil ring issues.
Just drop equal amounts of oil down each bore and carry out a compression test and compare your dry and wet readings.
It is not conclusive but will give you an indication. :thumbs:
  • 3 months later...
