Engine / Gearbox mounts
Spatt
Hi folks
I suspect my engine and or gearbox mounts are shot. Has anyone changed theres and what are these "Poly bushes" my friends keep telling me about
Hoping there is an easy DIY guide and they're not too pricey, Any info advice would be great.
Thanks
Matt
Hi Matt,
You may wish to PM Ewen at Clark Motorsport, they stock Powerflex engine mounts for the 350Z, I'm sure he will offer advice on both engine and gearbox mounts.
Earlier posts on the forum, have indicated that changing gearbox mountings can improve shift characteristics and reduce noise/vibration.
I understand that the generic term, "polybushes" refers to steering/suspension bushes.
Ridz
Edited by Ridz
Cheers ridz I'll get in touch.
I believe from a little research it's two engine mounts and one gear box mount.
I'm having big problems with shifting gear near the limiter and a friend recommend either "polybushing" or solid mounts..
Need to get this done because it's destroying my y pipe I think.. I've been through two y pipes in 12 months :(
