fsrowsell Posted August 11, 2015 Share Posted August 11, 2015 Good day all, Just finish installing a Stillen stage 3 supercharger on my 04 350z and now the engine won't start. It looks like I am not getting any power to the ECU. When I turn the key on I do not get a CEL light, no prime from the fuel pump, Fans come on, and the red light on the dash stays on. After doing a search on here, I saw a post back in 09 started by AndyRigby. He was having a similar problem. On post #49, Mark suggested to check power going to PINs 109,119,120, & 121. I did this and I am not getting any power to these PINs! Not even to the permeant power PIN 121. What would be stopping power going to the ECU wiring harness? Cheers Felix Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 11, 2015 Share Posted August 11, 2015 (edited) Without a lot more info it's a bit hard to diagnose - did you fit any sort of aftermarket ECU? However my first thought is you have shorted something out and blown a fuse start with the big set in the positive connector from the battery and work back from there. Was the battery removed during the installation? You can just fry the ECU if your not careful bit more info and myself and a few other members will do our best to help I'm sure. And Welcome to Forum Edited August 11, 2015 by Keyser 2 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 11, 2015 Share Posted August 11, 2015 Hi Felix, Welcome to the forum! Fans on immediately after you turn the key on usually means something wrong with the ECU. Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 11, 2015 Author Share Posted August 11, 2015 Cheers for the welcome! Yes the battery was removed for the install. I had to unplug the ECU and pull it up into the engine compartment. The kit required me to splice into a couple of sensor wires in order to piggy back a controller unit that comes with kit. I have triple checked these splices and they are OK. I will start checking fuses in the front compartment. Are there any other locations for fuses? Cheers Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 11, 2015 Author Share Posted August 11, 2015 Yes, I read that on the forum , which directed me to check the power supply going to the ECU. This is when I discovered that I have no power to the ECU. Hi Felix, Welcome to the forum! Fans on immediately after you turn the key on usually means something wrong with the ECU. Quote Link to comment Share on other sites More sharing options...
evilscorp Posted August 11, 2015 Share Posted August 11, 2015 Flat battery? Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 11, 2015 Author Share Posted August 11, 2015 OK Checked all the fuses. Found one dead 15A for the IGN & ECCS CONT. Replaced, but did not make any differance. Tried this little test of found on the net for checking if your IPDM is good or not. Mine failed the test! The test was: With the left door open, turn the key to ON position and within 20 seconds press the black button inside side of door jam 10 times(this button is for the dome light and chime). Then turn of key and within 10 seconds your horn should chirp if your IPDM is working correctly. If not it is bad and needs to be removed and checked over or replaced. So, my next step is to tray and remove the IPDM box. Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 11, 2015 Author Share Posted August 11, 2015 No, the engine turns over with no problem Flat battery? Quote Link to comment Share on other sites More sharing options...
evilscorp Posted August 11, 2015 Share Posted August 11, 2015 Sounds like you know what you are doing, just thought I would suggest the simplest thing first as 90% of cases its normally something simple. Good luck with your hunt and hope you aint after lots of power 1 Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 12, 2015 Share Posted August 12, 2015 (edited) Well the blown 15Amp was a good start - shame it didn't solve the problem Heard about the test for the IPDM but never tried it also heard mixed results, I know Harryjax (or his son) had a similar fail it turned out to be a sticky relay that kept blowing fuses I think. Back to you, more fuses in the box in front of the battery and behind the battery plus more in the drivers foot-well on the right behind the little black cover (assumes RHD) Fans coming on as Torquen has said can be ECU fault but also if the dash is removed and the little white box behind the AC controls (ribbon cable) is out or not connected the internal fans will come on full blast with ignition on, not sure which fans you were referring to. I would suggest you carry on looking for blown fuses if possible remove the piggy back just for the test start if you need an IPDM or even an ECU I would suggest giving Zmanalex on here a shout but if you do need a new ECU you are going to have to look at Uprev or similar to get the NATS removed/disabled or get get keys etc recoded. Keep us informed of the progress, where are you based? Good luck Edited August 12, 2015 by Keyser Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted August 12, 2015 Share Posted August 12, 2015 I would remove any piggy back stuff first and leave the ECU standard to see if there is any difference. 1 Quote Link to comment Share on other sites More sharing options...
The Chubby Ninja Posted August 12, 2015 Share Posted August 12, 2015 I had similar, no check engine light and immobiliser light. I had to get the nats removed and all was fine. I had put my old engine and ecu in a new car. Are you sure you have spliced into the right wires as it's as if it's that that's causing the ecu to play up Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 12, 2015 Author Share Posted August 12, 2015 Good morning all, I'm located in Canada, so my day is just starting I now have access to the cars wiring diagrams, which i'm sure will help me to trace my problem. I have reverted her back to the original wiring without the piggy back for the SC kit and it was the same results. I have triple checked my splicing of the SC kit unit and I am confidant that I have done it correctly. I even had a mate check it with me. Today I am going to trace the power wires coming from the ECU to it's source, to see what's stopping it from flowing correctly. I have put on meter on the power PINs on the ECU harness (119,120, &121) with the key on and concluded that there is no power going to them. I'll keep everyone info'd on my findings. cheers Quote Link to comment Share on other sites More sharing options...
Payco Posted August 12, 2015 Share Posted August 12, 2015 Haven't got time to read the entire thread now but there is a second fuse box in the footwell of the drivers side of the car. Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 12, 2015 Author Share Posted August 12, 2015 Payco, my car is LHD. So, would this be in the right side footwell were the ECU is? Haven't got time to read the entire thread now but there is a second fuse box in the footwell of the drivers side of the car. Quote Link to comment Share on other sites More sharing options...
Payco Posted August 12, 2015 Share Posted August 12, 2015 (edited) Mine is to the right of the steering wheel, directly below in the footwell area. I guess yours would be under your steering wheel too. Diagram below for you. Edited August 12, 2015 by Payco Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 12, 2015 Author Share Posted August 12, 2015 Cheers mate, but unfortunately all fuses there are good. Everything is pointing to a bad IPDM! Mine is to the right of the steering wheel, directly below in the footwell area. I guess yours would be under your steering wheel too. Diagram below for you. Quote Link to comment Share on other sites More sharing options...
Payco Posted August 12, 2015 Share Posted August 12, 2015 ok, hope you get it sorted. Will be interested to hear what the issue is and how you resolve it. Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 12, 2015 Author Share Posted August 12, 2015 Will, I've come the the conclusion that it is indeed my IPDM that is at fault! I have power going into the IPDM but, no power coming out to the ECU. To prove this further, I put power to wire going to PIN 120 and I am getting power to the ECU! I have a IPDM on order and should receive it in a couple of day. Stay tuned for update! Cheers Felix Quote Link to comment Share on other sites More sharing options...
glrnet Posted August 12, 2015 Share Posted August 12, 2015 Good luck Felix Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 18, 2015 Author Share Posted August 18, 2015 It breaths again!!! Had the new IPDM come in the post today. In stalled it and away she goes! Now it's time to try my new power! Cheers Felix 3 Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted August 19, 2015 Share Posted August 19, 2015 What's ipdm ? Quote Link to comment Share on other sites More sharing options...
SteveM Posted August 19, 2015 Share Posted August 19, 2015 I believe its Intelligent Power Distribution Module Quote Link to comment Share on other sites More sharing options...
Keyser Posted August 19, 2015 Share Posted August 19, 2015 It breaths again!!! Had the new IPDM come in the post today. In stalled it and away she goes! Now it's time to try my new power! Cheers Felix Excellent news fella Quote Link to comment Share on other sites More sharing options...
fsrowsell Posted August 19, 2015 Author Share Posted August 19, 2015 Yes, the IPDM feeds power to various systems and one of them being the ECU. Which in my case no power was going to my ECU. Cheers Quote Link to comment Share on other sites More sharing options...
