Alex350z Posted August 11, 2015 Share Posted August 11, 2015 Bleeding my clutch, it feels ok but there is a really soft bit at the start and then it goes stiff? How do i get rid of this? Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 11, 2015 Share Posted August 11, 2015 There has got to be a bit of "clearance" If you are getting gears easily then all will be fine. If not, you will still have air in the system and following the recommended bleed procedure will eradicate this. Alex. Quote Link to comment Share on other sites More sharing options...
Alex350z Posted August 11, 2015 Author Share Posted August 11, 2015 There has got to be a bit of "clearance" If you are getting gears easily then all will be fine. If not, you will still have air in the system and following the recommended bleed procedure will eradicate this. Alex. Thanks Alex, all is well, just slightly spongy at the top!Cheers Quote Link to comment Share on other sites More sharing options...
